Hello to TBN
/ Hello to TBN #1
Aussi Farmer Bob
Crows Nest, QLD
Deus Fahr 4.75 Agrolux
Hi Guys,
Im a farmer in Australia with a small 300 odd acre property, 70 odd breeding cattle, and rely on the tractor for everything from post hole digging to making roads.
I own an Deutz Fahr 60 . 4.75 Agrolux. Purchased new in 2011 and now has 307 Hours on it. Tractor is mostly used for slashing, light land clearing moving dirt and shallow digging with a 1000Kg SWL Titan FEL.
So far the tractor has been maintained on an ongoing basis. Lots of loose nuts and bolts. This is understandable however may be alleviated by using a heap more nyloc nuts. Tractor is currently in the shop at the moment with a front diff problem - more to follow I believe.
Still, the tractor punches/ works above its weight and has been particulalry reliable to date.
/ Hello to TBN #2
G'day AFBob,
Welcome to TBN!
We seem to use and abuse our little Kubota B2320 pretty well, despite using it as a utility tool for maintaining and landscaping our paltry 8+ acres. You can tell that we're not using it for farming because despite being also having been bought new in June 2011, it only has about 113 hours on it so far.
Sorry to hear that it is having an issue, but hopefully it will be back in working order ASAP.
Good luck, and again, welcome to TBN!
Thomas
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
2022 J&M TF212 Rolling Harrow (A63116)
2022 J&M TF212...
PORTABLE SAND BLASTER (A62131)
PORTABLE SAND...
2023 John Deere 6120M Tractor (A63109)
2023 John Deere...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
International S1900 (A63118)
International...
