Hello-Need Some Electrical Advice
   / Hello-Need Some Electrical Advice #11
Sometime My 675 will not start and it is the connector on the pto switch. I guess dust or mud gets in it as it is under the rear axle. There is also a neutral safety switch on the trans. You can bypass both the PTO and neutral switch by unplugging them and jumping the two wires together with a piece of wire.
Been too wet to really do anything before now, but I got back on it today. I got it running.
While tracing wires, I found there is more than one ground. On the hidden ground, the crimped steel connector had rusted, breaking the ground. Ants had also clustered on the switch poles for lights. So even after fixing the ground, it took a little more work.
Again, I thank you all for the help. Y'all stay well. :thumbsup:
2025 HT360W Mini Stand-On Track Loader Skid Steer (A55851)
2025 HT360W Mini...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2017 Bobcat T770 Compact Track Loader (A55315)
2017 Bobcat T770...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
JOHN DEERE 3020 TRACTOR (A54756)
JOHN DEERE 3020...
