Hello from Vermont!
/ Hello from Vermont! #1
Perididdle
None...yet!
Hi folks. Just a gal who bought a farm with her friends (living the millennial dream!), on the hunt for the perfect tractor for us to build up a little operation. My dad's a mechanic but I'm not quite as engine-savvy -- but he's back in Missouri, so I need to build up some of my own know-how. :)
We have 48 acres in Addison County, VT, about 60/40 woods and pasture. We're planning on horses (lots), goats (lots), cows (one or two), and maybe a little of everything else...still to be decided. Can't wait to tap your brains!
/ Hello from Vermont! #2
Welcome to the forum from upstate NY.Vermont gets a fair amount of snow so that should also come in the your consideration.
For the live stock if you stay with small square bales you should be able to get by with;a 4 wheel drive,front end loader and maybe a decent sized rear blade(7') for starters.A cab would be nice for winter.So a 35-40 H.P that weights at least 3,000 lbs.bare tractor.
Lots of brands to chose from;any close dealers?
Oh yeah, snow plowing is definitely one of our main considerations
Square bales are ok! And 35-40 was roughly my thought, maybe up into the 50 HP area. So good to know! This is perfect.
I actually just did a post in the tractor buying forum with lots more info. We're probably going super used, wouldn't mind buying from an owner or small small dealer. We definitely have John Deere, Kubota, and New Holland dealers in these parts; but we're well out of their price range. For now. :)
/ Hello from Vermont! #4
:welcome: to TBN...enjoy.
Wishing the best in your search for tractor and there some good second hand 2WD tractor but far and few between,also consider heater for the tractor engine...cold weather a coming.
/ Hello from Vermont! #5
Welcome to the forum! That sounds like an adventure.
:welcome:
/ Hello from Vermont! #6
You may want to touch base with all your dealers;have them put you on a list for incoming used tractors.Be forewarned ;good used tractors aren't "cheap".Pre tier 4 tractors command a premium(those in excess of 26 H.P built 2013 or earlier).
/ Hello from Vermont! #9
... We definitely have John Deere, Kubota, and New Holland dealers in these parts; but we're well out of their price range.
Same issue many of us encountered and why we looked at other brands. Check out LS tractors and see if you have a dealer nearby and go talk to them if so.
/ Hello from Vermont! #10
Welcome to TBN, let us know how your tractor buy goes and hope you can find something very usable that doesn;t break the bank.
/ Hello from Vermont! #11
Welcome to living the dream in VT. The only bad news will be your taxes :)
I bought a Kubota MX5400 from PinnacleView equipment which is off exit 5 on 91, probably too far from you. I'm guessing Townline Equipment is closer to you, as Kubota dealers go. No idea if there are any closer to you. I have Deere dealers equidistant, dealer support/proximity is important to me, but I'm happy with my decision to go Kubota.
Clearing snow is a big deal and a step I haven't taken yet with my tractor, good luck figuring that out. Don't forget chains for your tires.
I'm still considering my options here. I ruled out a front mounted blower, unless you have a mid-pto option, it's probably too expensive anyway. I don't really want to go in reverse to snow blow, I am considering pull-type rear snowblowers. Means adding more hydraulics, I have none in the rear. A snow pusher and your bucket can be used too, if we have a light winter, you never know what you're going to get in Vt these days.
If you're on hilly terrain (and who isn't along the Green Mountains), then consider the width of the tractor and stability requirements, which is one of the things that prompted me to buy the MX5400 vs the L3901, it's 20+ percent wider.
For me, my most used attachments are:
grapple - for clearing trees, brush, and pulling big rocks out of the field - this is my most frequently used implement. Trees always coming down somewhere.
bucket - for driveway work, hauling mulch, etc.
rear blade - for driveway grading and ironically the hardest attachment to learn to use effectively
rotary cutter - for cutting the field
I have pallet forks I don't use much, though they are arguably more capable of moving big rocks out of the field. The grapple loses total power with the hydaulics used to open/close it.
If you're going to be gathering trees for firewood, consider a heavier tractor and winch setup for it.
HOOPER 95" X 30' TRI-AXLE GOOSENECK TRAILER (A63291)
HOOPER 95" X 30'...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2019 Dodge Grand Caravan Van (A61574)
2019 Dodge Grand...
2024 Kubota SVL97-2 High Flow Compact Track Loader Skid Steer (A61572)
2024 Kubota...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
76" X 15' BUMPER PULL TRAILER (A63291)
76" X 15' BUMPER...
