Hello from the Midlands of SC
   / Hello from the Midlands of SC #1
graywarrant
Cayce, SC
Kubota L3400
Hello All -
We live near Columbia, SC and just purchased a new to me Kubota L3400 MT4WD. We have 10 acres in WNC and I'm in a lease of 400+ acres for hunting and both properties always seem to need some work done that requires more than a shovel.
Not knowing it's maintenance history I picked up the WSM and figured I would perform the 50 & 100 hour service procedures. I also had to rework the oil pan as there was a lot of seepage from the area - not sure why the PO was in there, but he left 11 of the 20 bolts out. Strange.
Headlight assy was broken so I replaced with a 17" LED light bar, oil and filter change (and oil pan rework), temp gauge hooked back up and still to do the hydraulic fluid & filter, front axle fluid, all points greasing, engine coolant and figure out why the GP key switch position seems to do nothing.
It does experience a bit of the jerky 3pt hitch syndrome common with the L3400, but nothing I can't live with. Other than that, the unit seems to be in excellent working condition as one would expect of a low hour tractor.
So far for attachments, it came with a Gannon 66" rollover box blade (earthcavator?), a buddy had an extra landscape rake which he donated and I am searching for an FEL, brush hog and ???
Other projects planned - rear work lights, toolbox, 3 spool valve (2 for rear, one for front grapple once I source an FEL), widen the rear tire stance, tire ballast and to use the darn thing.
I've been lurking for a while and already appreciate the collective knowledge here and I know I will be digging for more as well as one day adding back to the community.
Wishing you all well -
Ray
   / Hello from the Midlands of SC #3
:welcome:
\To TBN Ray. This is a great site to get answers for any question.
When I was stationed at Shaw AFB in Sumter, I went through Columbia a lot. Much nicer area than further south.
   / Hello from the Midlands of SC #4
   / Hello from the Midlands of SC #6
:welcome: to TBN Ray...enjoy.
   / Hello from the Midlands of SC #7
Eutawville>> small town outside of Santee>> on the lake.. My little piece of Heaven..
Been through there on the scooter before, nothing wrong with a small town and there is some nice riding all down throughout that part of the state.
jeff9366 - Thanks for the links, the implement link from LSU is very informative.
mddorange - Yes, sadly the I95 corridor only gets news & attention during elections, but there are some nice MC'ing roads and small towns to check out down there and good people. Thanks for your service - I'm 34 years in Army Guard, full-time for 30, 1 OIF and 2 OEF tours under my belt. Nothing exciting as I work in communications, mostly strategic.
   / Hello from the Midlands of SC #9
Welcome. I'm also from the Midlands....about 20 miles NW of Columbia.
Folks are very helpful on here so ask any questions you may have any somebody will try to answer.
   / Hello from the Midlands of SC #10
Hi Ray. Welcome to the forum!
2016 FREIGHTLINER CASCADIA SLEEPER (A58018)
2016 FREIGHTLINER...
2009 International 7400 Altec A77-TE93 92ft. Material Handling Bucket Truck (A55973)
2009 International...
2019 Haulotte Star 20 ACE 19ft Scissor Lift (A55973)
2019 Haulotte Star...
WhisperWatt DCA-85SSM 85kVA Towable Diesel Generator (A55973)
WhisperWatt...
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
air compressor (A55758)
air compressor...
