hello from Texas I have a New Holland compact tractor for 1925
   / hello from Texas I have a New Holland compact tractor for 1925 #1
Vic139
Sherman, TX
New Holand ford 1925
I have a New Holland compact tractor for 1925 3 cylinder diesel I am getting fuel to the pump but will not stay running ! bad injector's? or bad pump? will not run over 1000 rpm then dies.:confused::confused::confused:
   / hello from Texas I have a New Holland compact tractor for 1925 #2
Getting fuel to the pump, how about to the injectors? Is there a filter between the pump and injectors?
no filter between pump and injectors unless it is in the pump. I will crack the nuts on the injectors today to see if fuel is getting that far!
   / hello from Texas I have a New Holland compact tractor for 1925 #4
Check to be sure fuel return line back to tank isn't plugged. Have cleaned/changed fuel filter??
yes did not have the problem until I changed the fuel filter and bled the line to the pump.
   / hello from Texas I have a New Holland compact tractor for 1925 #6
Sounds like an air leak to me...
I have changed the filter on my 1720 many times before and sometimes I would need to purge the air out of the system with the air purge screw...
bled the line to the pump. done
Yes it has been up and running for a while now I put seafoam in the tank and it cleaned a lot of slim out of it had to change filter again
Willmar Wrangler 4500 (A56435)
Willmar Wrangler...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52709)
2007 CATERPILLAR...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
2016 INTERNATIONAL LF687 SLEEPER (A58018)
2016 INTERNATIONAL...
