hello from Texas I have a New Holland compact tractor for 1925
   / hello from Texas I have a New Holland compact tractor for 1925 #1
Vic139
Sherman, TX
New Holand ford 1925
I have a New Holland compact tractor for 1925 3 cylinder diesel I am getting fuel to the pump but will not stay running ! bad injector's? or bad pump? will not run over 1000 rpm then dies.:confused::confused::confused:
   / hello from Texas I have a New Holland compact tractor for 1925 #2
Getting fuel to the pump, how about to the injectors? Is there a filter between the pump and injectors?
no filter between pump and injectors unless it is in the pump. I will crack the nuts on the injectors today to see if fuel is getting that far!
   / hello from Texas I have a New Holland compact tractor for 1925 #4
Check to be sure fuel return line back to tank isn't plugged. Have cleaned/changed fuel filter??
yes did not have the problem until I changed the fuel filter and bled the line to the pump.
   / hello from Texas I have a New Holland compact tractor for 1925 #6
Sounds like an air leak to me...
I have changed the filter on my 1720 many times before and sometimes I would need to purge the air out of the system with the air purge screw...
bled the line to the pump. done
Yes it has been up and running for a while now I put seafoam in the tank and it cleaned a lot of slim out of it had to change filter again
WESSEX RMX500 LOT NUMBER 44 (A53084)
WESSEX RMX500 LOT...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2017 TAKEUCHI TB240 EXCAVATOR (A51246)
2017 TAKEUCHI...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A52472)
2017 GRAND DESIGN...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
