Hello from Tennessee
   / Hello from Tennessee #1
fannascar
John Deere 1250
Going to jump right to a question. Had starter rebuilt on a 1250 John Deere tractor. Had nothing on tractor. Since rebuild it would only click with hot battery. Hooked truck up to it , with battery still hooked, and it turned over but then went back to clicking. I put meter on the battery and all was good. Hooked to ground then post on starter all good. But when I turned the key the reading dropped to like 2.3. Does this mean I do not have enough cranking amps to turn over the tractor, or is the rebuild not good? Also the cables were smoking and got very hot. Thanks
   / Hello from Tennessee #2
If the cables were smoking it sounds like something is shorted somewhere.
   / Hello from Tennessee #3
:welcome: to TBN...enjoy.
Might want to ask question in its post you should get more responds.
How do I post?
   / Hello from Tennessee #5
If your voltage is dropping that much on a good battery, you have a bad rebuild. Do you have a clamp on amp meter? It would be interesting to see how many amps it is drawing because it sounds like you almost have a direct short.
   / Hello from Tennessee #6
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
Vermeer T-658 Tracked Trencher (A52384)
Vermeer T-658...
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2005 Dodge RAM 1500 (A50123)
2005 Dodge RAM...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
