Hello from Tennessee
   / Hello from Tennessee #1
fannascar
John Deere 1250
Going to jump right to a question. Had starter rebuilt on a 1250 John Deere tractor. Had nothing on tractor. Since rebuild it would only click with hot battery. Hooked truck up to it , with battery still hooked, and it turned over but then went back to clicking. I put meter on the battery and all was good. Hooked to ground then post on starter all good. But when I turned the key the reading dropped to like 2.3. Does this mean I do not have enough cranking amps to turn over the tractor, or is the rebuild not good? Also the cables were smoking and got very hot. Thanks
   / Hello from Tennessee #2
If the cables were smoking it sounds like something is shorted somewhere.
   / Hello from Tennessee #3
:welcome: to TBN...enjoy.
Might want to ask question in its post you should get more responds.
How do I post?
   / Hello from Tennessee #5
If your voltage is dropping that much on a good battery, you have a bad rebuild. Do you have a clamp on amp meter? It would be interesting to see how many amps it is drawing because it sounds like you almost have a direct short.
   / Hello from Tennessee #6
:welcome:
Welcome to the forum!
I'm going to move this thread over to our John Deere section.
2014 Jeep Grand Cherokee SUV (A51694)
2014 Jeep Grand...
2015 Ford F-350 Utility Flatbed Truck (A51692)
2015 Ford F-350...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A51692)
2007 Ford E-450...
2013 Morooka MST-2200vd Crawler Carrier (A52384)
2013 Morooka...
2011 Dodge Nitro SUV (A51694)
2011 Dodge Nitro...
John Deere MX10 Rotary Cutter (A53117)
John Deere MX10...
