Hello from Inverness FL
   / Hello from Inverness FL #1
fhp6
Inverness, FL
Mahindra 4540 4WD
New Mahindra 4540 owner problem with left front wheel. Tried to torque front lugs only to find that the left front lugs had 3 of the 6 cross threaded. Dealer replaced bolts but now I need a tap to clean the threads.
   / Hello from Inverness FL #2
Hi, and welcome to TBN. If you need a tap to clean the threads take a bolt with you to a decent hardware store, or better yet a hardware supplier.
   / Hello from Inverness FL #4
:welcome: to TBN...enjoy.
   / Hello from Inverness FL #5
Welcome!
Why didn't the dealer fix the problem, assuming you hadn't had the wheel off before.
David from jax
To my knowledge the wheel had not been off the tractor. I had it to the dealer for the 50 hour service and some work on the hydraulics at the same time. Torquing the wheel lugs is part of the 50 hour service. They must have removed the wheel for the hydraulic service ??? and when it was reinstalled three of the six lug bolts were cross threaded. I didn't realize they were cross threaded until I checked the torque on the lugs.
They would have fixed it but I didn't want to take it to the dealer. If can tap the wheel hub holes to accept the new bolts it will be done. Otherwise I'll put a couple of bolts in the wheel and take it to them. Dealer already told me that they will warranty the hub if needed.
   / Hello from Inverness FL #7
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Mahindra section.
   / Hello from Inverness FL #8
As I understand what I have read, you have new lug studs from your dealer to install in your hub.
If this is correct, take one of them with you to a big box store, they usually have a setup in their bolt aisle to ID bolt/nut sizes.
You may or may not find a tap there, but you should know you diameter and thread pitch after this visit.
   / Hello from Inverness FL #9
Welcome to T-B-N from nearby Gilchrist County.
John Deere 1025R Tractor (A50514)
John Deere 1025R...
2008 Ford F-250 (A52748)
2008 Ford F-250...
64" Severe Duty rock bucket (A47384)
64" Severe Duty...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
2015 F-550 Bucket Truck. (A52748)
2015 F-550 Bucket...
