Hello from British Columbia
   / Hello from British Columbia #1
JJO
BC, Canada
Ford 4610 Okanagan Orchard Special 3952
Hello everyone,
I'm back using a tractor after 35 years! I became the keeper of my current tractor last year when I bought it with a property. It is a Ford 4610 Okanagan Orchard Special. This is a Ford 4610, with front axle and steering from a 3910, low slung exhaust, internal air intake and wide-set, fat rear tires. It works well on our hilly vineyard, reasonably stable side-to-side and its low stance and lack of upper exhaust and air intake lets it fit between our close-set top heavy lyre trellising.
Sitting on the 4610 for the first time and giving it a drive was strangely familiar. It was like the Ford 4000 we had on our farm years ago, but easier; power steering, power breaks, hydraulic toplink - all mod cons!
Jobs slated for next month are:
  1. Change rear axle/hydraulic fluid & filter - that is a surprising amount of hydraulic fluid 45.7 litres (48.3 US quarts).
  2. Change transmission oil.
  3. Finish resealing a leaking power steering cylinder and change PS fluid & filter.
  4. ..and most intimidating, fixing the leaking gasket on the top cover on the diesel injection pump and replacing one of the studs (which I probably broke when trying to stop diesel spraying out of the side). Must thank Lance Bundy Bears Shed for giving me the confidence to tackle this one.
I've already found these forums helpful on the topic of oil and hydraulic fluid, hopefully, I'll be able to contribute too.
James
   / Hello from British Columbia #2
G'day Mate and welcome to TBN from Downunder.
Enjoy the site. (Many a fine day skiing Big White & Silverstar)
   / Hello from British Columbia #3
:welcome: to TBN James...enjoy.
   / Hello from British Columbia #4
Hi James.
Welcome to the forum. We're happy to have you as a member.
:welcome: :tractor:
   / Hello from British Columbia #5
Welcome to TBN and the forum. I'm just a bit south of you. Born & raised in the Okanogan @ Omak. Now living 25 miles due SW of Spokane. Sounds like a nice tractor.
   / Hello from British Columbia #6
Hi James. Welcome from Victoria.
I’m retired now but but still have a few Ford / New Holland parts around.
PM me if you’re stuck.
Here’s a Ford 4600 I sold recently. Not quite as low as yours...
Thanks very much for the welcomes - new to the Okanagan, relocatimg from Hong Kong.
   / Hello from British Columbia #8
Well, not only a change in cultures but a fairly significant change in the weather. You probably aren't about to see 60's & 70's with rain in the upper Okanogan this time of year. Good luck with your new vineyard and life style. You have picked a really beautiful area to relocate into.
   / Hello from British Columbia #9
And a welcome from the other end of Canada, well almost.
Am in La Belle Province, Quebec.
Don't forget, TBNers like lots of pics!
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A55973)
2015 Peterbilt 567...
OMEGA 20 TON CRANE (A58214)
OMEGA 20 TON CRANE...
2014 Toyota Camry (A56859)
2014 Toyota Camry...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
STAINGLASS SHIP SCREEN (A58374)
STAINGLASS SHIP...
2020 DRAGON ESP...
