Hello from Belgium
/ Hello from Belgium #1
jpslootmans
Sint-Gillis-Waas, Belgium
Yanmar YM1610D
I am a new member and the reason why I registered is (of coarse) a problem I am having. I discovered TactorByNet while googling for a solution but unfortunately I had no luck so far.
I hooked a little plow (designed for a two wheel tractor) to my Yanmar YM1610D but it wont stay in the ground.
When I start plowing it goes in the soil for about 8 inches but then it gradually comes up until it just slides over the surface.
Is it because it is not heavy enough or is there some adjustment that has to be made?
If anyone can help it would be largely appreciated.
JP
/ Hello from Belgium #2
It could be a weight issue or you might shorten the top link to get a better angle, "usually" a plow will try to go deeper if set properly. Once you have your initial furrow, you will also need to adjust the lower links to keep the angle side to side correct as your tractor will now be on an angle with the tire in the furrow.
There are some pretty good threads here on plowing.
/ Hello from Belgium #3
Welcome - Yes it sounds like you need to adjust to get a better angle. Have you viewed the video on Everythingattachments.com?
/ Hello from Belgium #5
I found w/ this forum that if you post up pictures your more likely to get
more quality input from folks. :thumbsup: Welcome...
/ Hello from Belgium #6
Welcome:thumbsup::thumbsup:
This just may be a case for "Hercule Poirot"!:D
Check the plow mounting so that at the desired depth the actual plow, which may be offset, is in line with the centerline of the tractor. Then make sure the share is sitting level or just slightly below level. You may also have to add a chain to limit the depth the plow will go down.:):confused:
COVINGTON IR PLANTER (A62130)
COVINGTON IR...
UNUSED ATS GAC40Y 40 GAL.AIR COMPRESSOR (A62131)
UNUSED ATS GAC40Y...
832655 (A61165)
832655 (A61165)
Reynolds 8CF Scraper (A64047)
Reynolds 8CF...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
UNUSED RAYTREE RMRB72 - 72" POWER RAKE BUCKET (A62131)
UNUSED RAYTREE...
