Hello from a new Branson 2400h owner.
   / Hello from a new Branson 2400h owner. #61
Jeff
Can you analyze how the oil is supposed to flow thru that valve to determine if the spool is not positioned correctly. I realize easy to be armchair mechanic vs having parts in hand but a single sliding spool should not be this difficult.
Solved!
The main spool has another rather small spool inside it that in my case was stuck.
Cleaned it well and reassembled. Lift arms now raise at idle.
Branson 2400h position control valve fix.
   / Hello from a new Branson 2400h owner. #63
Jeff
Great job on diagnosis and thanks for posting the solution.
   / Hello from a new Branson 2400h owner. #64
Great work on troubleshooting this one out Jeff. You really had to go arms deep on this one but you figure it out.
I suspect this would be a tricky one for a not so good dealer.
   / Hello from a new Branson 2400h owner. #65
Congrats, you got yourself a nice tractor for cheap despite unraveling all the mickeymousing done by the previous owner.
INOP/NON-RUNNING 2005 Kenworth T800 Tandem Axle Day Cab Truck, VIN # 1XKDD09X85R091127 (A54865)
INOP/NON-RUNNING...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A53421)
2018 Bobcat T590...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
Two Pairs of 8ft Fork Extensions (A53421)
Two Pairs of 8ft...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A52706)
CATERPILLAR 631E...
