hello all
/ hello all #1
wenailem1
need advice, my dynamark rider went on fire and torched to whole front end off. everything in front of the steering column is toast. my question is , will the motor be fine.
thanks
/ hello all #2
depends on how hot the fire was. if very hot the block is probably warped. the block will melt at approximately 1100 degrees
/ hello all
is there any thing i can do to see if its warped,,,,,,,maybe turn the flywheel by hand?:thumbsup:
/ hello all #4
Turning the crank will let you know if things are straight at the bottom end, but that won't tell you too much.
Frankly, I suggest you talk to your homeowner's insurance agent to see if the mower is covered. It's probably not worth repairing.
How did it catch fire? Did you refuel it when the engine was still hot?
/ hello all #5
I agree with Roy. Not much there to salvage. A lot of aluminum in engines today and even if just the carb is toast that in about $150 to replace. I would let the insurance company deal with it.
Chris
/ hello all
thanks guys, i think the fuel tank cracked, temps fluctuating here in ontario like crazy, it is my backup beater to cut the junk, sticks rocks etc. we run j/d 214 as our primary.
awesome site.
:thumbsup:
Arrow Quip RLDR Alleway Roll Door (A64047)
Arrow Quip RLDR...
2012 Gehl DL11-55 11,000lb. 4x4 Rough Terrain Telehandler (A61572)
2012 Gehl DL11-55...
2020 FORD RANGER(INOPERABLE) (A63569)
2020 FORD...
2006 DIAMOND C 40' 10 TON GOOSENECK TRAILER (A63290)
2006 DIAMOND C 40'...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
