hello all
   / hello all #1
wenailem1
need advice, my dynamark rider went on fire and torched to whole front end off. everything in front of the steering column is toast. my question is , will the motor be fine.
thanks
   / hello all #2
depends on how hot the fire was. if very hot the block is probably warped. the block will melt at approximately 1100 degrees
   / hello all
is there any thing i can do to see if its warped,,,,,,,maybe turn the flywheel by hand?:thumbsup:
   / hello all #4
Turning the crank will let you know if things are straight at the bottom end, but that won't tell you too much.
Frankly, I suggest you talk to your homeowner's insurance agent to see if the mower is covered. It's probably not worth repairing.
How did it catch fire? Did you refuel it when the engine was still hot?
   / hello all #5
I agree with Roy. Not much there to salvage. A lot of aluminum in engines today and even if just the carb is toast that in about $150 to replace. I would let the insurance company deal with it.
Chris
   / hello all
thanks guys, i think the fuel tank cracked, temps fluctuating here in ontario like crazy, it is my backup beater to cut the junk, sticks rocks etc. we run j/d 214 as our primary.
awesome site.
:thumbsup:
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2002 Ottawa 30 Spotter Truck (A52384)
2002 Ottawa 30...
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A53473)
2022 Gravely...
PALLET OF MISC PUMPS (A51248)
PALLET OF MISC...
1999 Case 850G Crawler Tractor Dozer (A51691)
1999 Case 850G...
