Loader Hello all and I need help!
   / Hello all and I need help! #1
mmarmino
cynthiana
ford 445a
Hello all!
New guy here. I purchased a Ford 445A last year and love it. When I bought it, the loader bucket was pretty worn with many rust holes in it. But after a few hundred hours and after moving many kentucky rocks, its slap wore out! Question is does anyone know where to look and what else might fit it?
   / Hello all and I need help! #2
I would take it to a GOOD welding shop and have them repair and reinforce the existing bucket.
$300 for a GOOD rebuild will be cheaper than any alternative and you will not have fit issues.
   / Hello all and I need help! #3
You could also have the welding shop make a set of forks for it.
   / Hello all and I need help! #4
I have a set of Ford factory loader forks sitting in my barn.
They are not quick attach, and have been in the barn for 30 years!
30 years ago I had a welding shop make me a set just like these.
I have used, and loved them for 30 years.
Forks are the absolute handiest tool to have, and I do not need to leave the seat to hook them up.
The capacity of my factory forks is 2000 lbs., the capacity of this type, out beyond the bucket, is only 1000 lbs.
Works for me though!
   / Hello all and I need help! #5
Chances are it's primarily the bottom, and a little up the back that is rusted, the rest is probably fairly solid so it would be cheaper to have a fab shop cut out the bad steel and put new it, they can probably roll it to match. Straighten things that need it and add a bit of flat bar up the sides to keep it from curling like that again and you should be good to go.
   / Hello all and I need help! #6
Welcome to TBN!!!
I'd do cheap repairs to the bucket until it just won't work anymore. From the pic, it doesn't look too bad.
Not sure how this discussion got off onto forks...
   / Hello all and I need help! #7
Repair, repair, repair.
I can't help, I do not live near cynthiana
Thanks for the replies, I've been off the net for the last week. I did talk to a fab shop today and he quoted me $400 to rebuild it
   / Hello all and I need help! #9
For $400 you can buy a good welder and learn to do it yourself.
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
2020 VOLVO 760 TANDEM AXLE SLEEPER (A57880)
2020 VOLVO 760...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
