Heli coil kits??
/ Heli coil kits?? #21
Like Sandlot posted,why not use an oversized self-tapping drainplug?Some are even available in a second oversize.If you're really paranoid,install the plug,remove and flush with oil,reinstall-good to go.
/ Heli coil kits?? #22
I think they just want to do it the hard way. SimS has a good idea too, the rubber plug type works like a boat drain or thermos bottle plug. Stick it in and tighten the wing nut causing the rubber plug to expand. Oh well! ;)
/ Heli coil kits??
Actually, we want to do it so we do not have to replace the pan, and if we do not have to drop it, the better. It is aluminum and expensive, so we are open to ideas.
Keep em' coming!!
/ Heli coil kits?? #24
Will,
The oversized self tapping drain plugs are made to do just that. Just screw it in. Pull it out, run a couple quarts of oil thru it to flush, put it back in, fill to normal level. Done!
/ Heli coil kits?? #25
Keep em' coming!!
In the mid 80 I worked on the VW rally cars for the factory US team and then race VW Golfs my self in the national rally series. I know these car inside and out Throw the ALUM pan away. and Buy a steel one about
75 or 100 new and can get at a import parts store no problem. Those pans would split at the drain plug hole if you over tighen them and if it is strip it has been over tighened most likely it will save you big head aches and they are easy to change on your back or a lift 10mm a 6 inch ext a swivel joint and a 1/4 inch ratcht that it. Oh jack stands and a jack. If you have any question I will be more than happy to help. Chris Putzier
/ Heli coil kits?? #26
What Chris said.
Fix it right once. Paul
/ Heli coil kits?? #28
All the 8 and 16 valve pans are the same. They put al pans on the car to cool the oil, The G60 cars and some of the turbo cars had them.One thing with VW'S just about every thing in motor and tran fittment are interchangeable Just look and see if the pan gasket is the same and it is a go Chris Putzier
/ Heli coil kits?? #29
I would insert it with a liberal dose of blue sealing, threadlocking locktite gel.I would grease the tap prior to tapping the thread insert helicoil hole and back it out often.I would start the tap, and stop, and look and check for true, and make my BIL check for true, and get out from underneath and go back and check that I was true before committing.
/ Heli coil kits??
Thanks all. Sorry for the delay. We ended up pulling the pan, and did the repair in the hous!! All good to go.
/ Heli coil kits?? #31
I commend you for doing it the right way. Pulling the pan is a lot easier than pulling the engine and replacing it. Not to mention the high cost of an engine. zman
/ Heli coil kits?? #32
I see you are planning to restore a MF-12 I think I have a hood for one and maybe some other parts. zman
Auger Cart (A65640)
Auger Cart (A65640)
Dueling Tree (A65640)
215603 (A63276)
215603 (A63276)
2021 JOHN DEERE 324L WHEEL LOADER (A65053)
2021 JOHN DEERE...
2014 CATERPILLAR 938K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2022 BOBCAT T76 SKID STEER (A65053)
2022 BOBCAT T76...
