height of TC33DA
   / height of TC33DA #1
indebt
Clarksburg West Virginia
Does anyone know the heigth of a Tc33DA with and with out the canopy. Curious if it would fit in my garage door with out lowering the ROPS.
   / height of TC33DA #2
Duane, I don't know about the 33, but my TC24 just BARELY fits under my garage door with the ROPS intact. If it had a canopy it would probably hang. Hope that helps, at least a little. /forums/images/graemlins/smile.gif
   / height of TC33DA #4
Duane,
My tractor shed has an 8' door, and my TC29 had ~ 1" to spare. My TC35 has 0" to spare. It squeaks every time i go through the door without an implement on the 3PH.
So,,, your TC33 should be real close to the same height.
   / height of TC33DA #5
I didn't think you could lower the ROPS with a canopy installed?
   / height of TC33DA #7
You're right to wonder. I have a NH canope on mine and it will NOT fit thru the door unless I use something to raise the door the extra 1~ inch needed for it to clear the door. It will go thru the opening, but the overhead door hangs down and has been re-alined several times. Best answer for the first time- go real slow.
If you don't have quite enough clearance....
1. digout the doorway - You do have a fel don't you /forums/images/graemlins/wink.gif
2. let air out of the tires
3. use something to push the door up - I use a lenght of plastic pipe
4. take the door off.....
   / height of TC33DA #8
It may not pass through the first time, but every time after that it will pass through just fine /forums/images/graemlins/grin.gif
I have an 8 foot high garage door, and my TC33DA (no canopy) fits thru with about 1/2" to spare. I make sure the door is as far up as it goes (and hasn't drifted down some) before I drive through with the ROPS up.
   / height of TC33DA #9
I don't know the answer off hand, but keep in mind it will vary a little depending on the tires you order. My TC33DA with industrial tires just BARELY fits through my 8' garage doorway, but only if I'm careful to shove the door up absolutely as high as it goes.
   / height of TC33DA #10
I just had a metal carport built with 10wx8h garage doors and my TC33DA clear the door fine with rops up but i don't have a canopy. Manual show it's 7' from ground to top of rops.
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
