Height and width of XR4000 cab series with R4's
   / Height and width of XR4000 cab series with R4's #1
RSR
Platinum Member
North Country, NY
LS XR4145HC
I'm looking for some real life measurements on an XR4100 series cabbed, LS. I'm debating between an XR3140 and XR4140, but my local dealer does not have the 4100 series cab in stock.
If someone has one of the 4100 series cabbed models, I would greatly appreciate a measurement of:
Width of rear, measured outside-to-outside on R4 tires.
Height to highest point of the cab, with R4's.
Finally, does anyone know if wheel spacers are available to increase the width? At the NY Ag show I was told, not very confidently, by a company rep that they "were pretty sure it was available". My dealer is unsure as well. If they are available, how much width (overall) do they add?
Thanks!
   / Height and width of XR4000 cab series with R4's #2
I have the XR4145 cab with R4 tires. I will get you measurements tonight when I get home.
As far as wheel spacers, I haven't found any. I am pretty sure you will need to look at aftermarket brands to find something.
Might try looking for New Holland Boomer 41 series, might get lucky.
   / Height and width of XR4000 cab series with R4's #3
I can’t measure my XR4155HC as it is 300 miles away however the XR4000 series owners manual lists the rear fender to rear fender width as 1611mm (63.4”) and height to top of cab (not including optional flashing beacon) as 2282mm (89.8”). These are the dimensions with the R1 tire (13.6-24 8 PR)
I haven’t been able to locate a definitive width difference R1 to R4 but the R4 will be slightly wider
Thanks! That would be a huge help.
   / Height and width of XR4000 cab series with R4's #5
Mines not a 4000 or 4100 series but an XR3037HC. Rear tire width with R4's is 66". Cab height is about 90" which includes an LED strobe light on top. Rear wheel spacers are available thu aftermarket companies that make them. They just need the bolt pattern and some basic info. I'm sure they've made or used spacers for NH on LS tractors.
   / Height and width of XR4000 cab series with R4's #6
Standing out here now with the tractor. Height is almost a perfect 90 inches tall. Width is 68 inches at the rear tires. I don't have the mirrors on any longer, and I'm pretty sure they poked out a bit more. But they fold in to flush with the cab. The bucket is 67 inches outside to outside.
Need anything else, let me know.
   / Height and width of XR4000 cab series with R4's #7
New Holland Boomer 45 cab, which is the XR4145, lists in their brochure as 69.1" wide and 94" tall.
Only thing is that it doesn't tell me what tires are used for that measurement.
Standing out here now with the tractor. Height is almost a perfect 90 inches tall. Width is 68 inches at the rear tires. I don't have the mirrors on any longer, and I'm pretty sure they poked out a bit more. But they told in to flush with the cab. The bucket is 67 inches outside to outside.
Thanks so much!
   / Height and width of XR4000 cab series with R4's #9
The Boomer is taller than the LS. It would not fit in my garage but the LS did.
   / Height and width of XR4000 cab series with R4's #10
Thats strange. Since the Boomer4x is the EXACT same as the LS XR4x. It's not a clone or copy, but the exact same tractor. Did you have different tires?
I took my measurements last night while the tractor was sitting on a concrete pad. I used a 4ft level on the top of the cab to reach the highest point. Keep in mind that I do not have beacons. Now, I didnt check the air pressure last night, but I do often enough. The highest point on my tractor is almost EXACTLY 90 inches.
2016 Kenworth T800 Tandem Axle Road Tractor (A47384)
2016 Kenworth T800...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
UNUSED FUTURE 7T HYD THUMB CLAMP (A51244)
UNUSED FUTURE 7T...
2016 CIMC 40FT CONTAINER CHASSIS (A52141)
2016 CIMC 40FT...
2001 Sterling Vac Truck (A50323)
2001 Sterling Vac...
