Grapple Heavy Grapple on Kubota L47?
   / Heavy Grapple on Kubota L47? #1
Leozepolusa
Austin, TX
Kubota B21 & L47 TLB
I am looking at buying a double claw grapple for my L47. I have my eye on two grapples weighing in the neighborhood of 1,000 lbs. The L47's lift at pins to full height is 2,800 lbs. Does anyone have experience with a heavy grapple on an L47 or similar spec tractor they can share? Just don't want to regret the grapple weight later, although I don't expect to lift more than 1,000 lbs with it. The L47's backhoe will serve as my ballast. I do want the construction features of a heavier grapple. Thanks
   / Heavy Grapple on Kubota L47? #2
A grapple is an easy thing to abuse. I don't have experience with your machine but understand it's very "robust" and I'd possibly sacrifice some grapple WIDTH before strength in its overall construction.
Put a ton in your bucket or pallet forks and put the tractor through some maneuvers that might either test the stability and spare capacity.
Short of an actual loaner/demo or finding someone with the same combination, I'd think that's about as good of a guess as you can expect.
Good luck. 👍
   / Heavy Grapple on Kubota L47? #3
That's a heavy grapple I would not put that on my tractor.. You can find one half that weight that will work and last...
   / Heavy Grapple on Kubota L47? #4
A 1000 pound grapple is a lot for that size machine. I’d look for something lighter.
  • Good Post
Reactions: jmc
   / Heavy Grapple on Kubota L47? #5
I run a 6ft cid grapple on my MX, yeah it's a little heavy at #950 but it handles it fine. I use a backhoe or rhino blade as ballast.
   / Heavy Grapple on Kubota L47? #7
Yes I do, it's super heavy duty
   / Heavy Grapple on Kubota L47? #8
I have a six foot - 800 pound - Land Pride grapple on my Kubota M6040. I've had it nine years and love what it can do. I have a 1000 pound Rhino blade on the 3-point and 1550 pounds of RimGuard in the rear tires. I can safely lift 3000 pounds. At this lift weight - I move in a "form" that I call - knuckle dragging. Just high enough to get the load off the ground. Check the weight lift charts in your FEL manual. You will find this - the lower the load, the more you can lift. The closer the load is to the lift pins - the more you can lift.
The ONLY thing I EVER lift to full height - an empty grapple. I simply have no job/or reason to lift any size load to full height.
The heavy loads I lift - chunks of pine tree trunk - LARGE rocks. On the internet I have found weight lift charts for logs( most all species ) and rocks( most all types). I use both of these charts extensively.
   / Heavy Grapple on Kubota L47? #9
I have a tc40 with 2,000lb lift capacity and a tomahawlk single lid grapple. I got the setup used and commercially used. Theres no bent tines or anything else bent. I have ripped 4in trees out by useing the grapple to dig the roots and scooped rocks to big to lift. I have the single lid brush grapple and it weights 415lbs.
Tomahawlk is made in the US and has a wide variety of grapples. A twin lid brush grapple they sell at 72in wide is well under 1,000lbs.
You have to remember that lift capacity is at the pin and things like a grapple put even that empty weight further away from the pin so a 1,000lb grapple may feel more like 1200-1300lbs to the tractor.
   / Heavy Grapple on Kubota L47? #10
My 66 inch root rake/grapple runs around 800lbs. I no longer have the spec sheet, so that is a SWAG.
I originally bought it for a tractor I had that was larger than my L47. Sold the tractor, kept the grapple.
I have had no issues with the combination, but if I was buying a grapple with the L47 in mind I would look for something lighter/smaller, maybe a 60 inch.
I've picked up some good sized logs and rocks and really have no complaints. Those L47s are powerful machines for their size.
1270 (A50490)
1270 (A50490)
Golf Cart (A51694)
Golf Cart (A51694)
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
RHINO X1808 LOT NUMBER 43 (A53084)
RHINO X1808 LOT...
