HoyeTractor
Gold Member, Approved Advertiser
Hi everyone,
It is waaaaaay to hot to do anything outside today so I thought I'd visit TBN and let you know that we FINALLY have the first shipment of our new heavy duty spindles in stock. They are designed for 2wd 1500, 1600, 1700, 1900, 2000, 240, 195, tractors that have a loader and are having problems breaking or bending the factory spindles. We had them built by a local Texas company and these new spindles are TOUGH!
1)- Machined from high strength billet steel- not just cast like the factory & aftermarket spindles.
2)- The horizontal shaft is around 15% bigger in diameter for added strength.
3)- Use all of you same hardware including the hub
4)- Includes bearings & seal
5)- Easy to install
6)- Made in the USA!
Yanmar Tractor Parts: SPINDLE-HEAVY DUTY -- NEW-- HOYE EXCLUSIVE!
We have also been busy with lots of other new projects like the 3 bolt flange mufflers for the 2200 & 2700, the small warning lights used on the 1300, 1500 and others, an adapter to let you use a standard 1/8" NPT oil pressure gauge.... and a lot more neat stuff is on the way! You can check them all out on our "new products" list below---
Yanmar Tractor Support Message Board • View forum - New Products!
5)- Easy to install
