Snow heavy blower
   / heavy blower #1
glsmith05
Barrie Ontario canada
265 john deere
Hello group, i just got a JOHN DEERE 265 with a blower attachment and found the blower very heavy so i purchased a lift kit and installed it and it helped allot but even before i put the kit on i found that i had to press downward with a fair amount of force to latch it into the locked down position.
is there an adjustment to reduce the pressure required to latch it down ?
   / heavy blower #2
:welcome:
You have to overcome the spring that is built in to help lift the mower deck...if I am hearing you correctly.
Do you need to latch it down, or can you let it float?
   / heavy blower
I do understand what you mean by the lift spring . no i don`t think it would work well floating it would bounce all over.because its almost neutral weight now since i put the lift kit on.
i don`t see how i can get arround it , i guess its not that bad.
thanks for the response.
   / heavy blower #4
Don't see any adjustment to make it less of a push to lock it down.
Heres hoping that you can make the move to hydraulic assist on your next trade. You deserve it. :)
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
