Heating of my Taishan TS804 tractor hydraulic pump and distributor
   / Heating of my Taishan TS804 tractor hydraulic pump and distributor #1
TS804
Taishan TS804
I use the tractor (TS804) for plowing in the farm. After 2 years we noticed heating of both the distributor and the hydraulic pump. The hydraulic oil also found its way into the engine oil. We got both parts changed but the heating came up again in a short while. We need some advice on what is happening.
   / Heating of my Taishan TS804 tractor hydraulic pump and distributor #2
Heating is a symptom of flow being restricted like a directional valve not returning to center or 3 point attempting to raise all the time.
Thanks but I’m not a technical person. Please explain 3 point
   / Heating of my Taishan TS804 tractor hydraulic pump and distributor #4
Your tractor may not have them but is arms on the back of a tractor used to connect implements like a box blade or scraper blade. They are raised via hydraulics on the tractor usually the lever is on the right side
Thanks we checked for all levers are on neutral.
Another observation: - the plow lifting and lowering is slower than before and the pump which is one we replaced is heating up.
   / Heating of my Taishan TS804 tractor hydraulic pump and distributor #6
To diagnose further you need to install a pressure gauge in the pressure line and watch this while the tractor is operating. There should be minimal pressure when no function is being operated and then pressure should rise when lifting the plow.
   / Heating of my Taishan TS804 tractor hydraulic pump and distributor #7
With 3 pt fully raised move 3 pt control lever forward just a small amount to determine if heating of oil goes away. If heating subsides it's possible 3pt feedback linkage isn't adjusted correctly.
Thanks
2012 Club Car Electric Cart (A53424)
2012 Club Car...
HarbinGer V3 Plus S/A Towable Light Tower (A52377)
HarbinGer V3 Plus...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED LANDHONOR ABC-13-125A HYD BRUSH CUTTER (A54757)
UNUSED LANDHONOR...
2017 HYDREMA 912HM ARTICULATED DUMP TRUCK (A52706)
2017 HYDREMA 912HM...
