Heating Budget
/ Heating Budget
The world is starting to wise up to the scale of the LEAKS involved with NG extraction and distribution... Something I can see turning out to be a source of emissions as big or bigger than the actual use of NG. At my old job we bought a building that had been occupied by a company that specialised in gas fitting, initially the place absolutely stunk of gas. We had to get a gasfitter in three times to fix all the leaks we found.
ShoeMaker's Children Eh ! Joking aside, those fitters should have had their licenses lifted.
I'm not big on incompetence, in any industry or trade.....
Rgds, D.
/ Heating Budget #102
Definitely agree, one of the leaks was well up in the roof space... Takes a lot of effort to be able to smell a lighter than air gas at ground level.
/ Heating Budget
Our stove, when running uses 5A, more if igniter must run. Run a power cord thru wall or floor so a small 1000W generator can run stove. The UPS beeping lets you fire up a generator before the house gets cold.
A beautiful thing.....
Rgds, D.
/ Heating Budget
As regulators start to catch up to this and pass the costs on to well and pipeline owners, that plentiful energy source aint going to be so cheap anymore :)
Passing Along Higher Costs..... not a Big Deal, if you are a 1%'er, or a Regulator controlling same....
For the peasants, it'll be a different ride.....
An engineer I knew, spent time visiting NZ, then moved his family your way. Said when visiting during your Winter, that he'd never ever been that cold indoors here.
He said that some people basically had no central heat, and got along with space heaters when needed.
While waking up in a house that was 47F down your way, and plugging in a space heater might be uncomfortable, the End Limit up here is way worse..... with frozen pipes only one stop along the way.....
Few places won't still have cheap electricity, for much longer at least.
Electricity is invisible, both literally, and in people's Minds. And that's too bad today, for a few reasons.
Any human activity has Enviro costs, and electric systems are no different.
If you want to know how bad it can get.... buy a guy who maintains underground HV lines a beer or 3, and listen closely.....
Rgds, D.
/ Heating Budget #105
Yeah our housing situation is pretty dire here, very much a hangover from the UK attitude of "put the pipes on the outside of the house, so they're easier to replace when they freeze"
Our place actually has insulation, double glazing, and heatpump + wood heat. Cozy.
/ Heating Budget #106
I have a pellet stove coming and am replacing the wood stove. 120-pound hopper and 3 day burn time is a plus. Also at 70, the firewood is getting heavier. I am making a shelf/pallet "quick attack" for the tractor to haul bags of pellets to the porch. That way I can set 20 bags at a time on the porch. I made two 60-pound capacity storage containers on casters to move the pellets into the house. Our heating oil just dropped from $3.48 to $3.25 which is great. Diesel is still up at $3.90. Our hydroelectric plant had to stop in mid-October, and we now generate on diesel. My electric bill doubled from last year.
Something I’ve been noodling through to add-on is a bulk hopper just foe convenience (laziness ?)
/ Heating Budget
A college buddy of mine moved to Oz 25 years or so ago. Caught up with him a while back, via Linked In.
That's one thing he said about Australia too...... typical houses had little/nothing for insulation. I've some across the same lack (vs. Canadian practice) in the American South.
Something about freezing plumbing in the dead of Winter.... tends to focus the mind :cool: .
IIRC, you are engineer, so you get thermodynamics, whereas the avg Joe may not...... likely why your house is not "normal" (y).
Rgds, D.
/ Heating Budget
Extra insurance.... going away for the weekend (remember when that was an option, in the PC days ?), or if you have a job that can run into extra OT/days away.....
I know I'd sleep better, when away....
Rgds, D.
/ Heating Budget
We replaced old oil boiler in 2009 with a Buderus 90% eff blue flame boiler for heat and DHW - cut our oil usage from 850 to 500 gal per year, and pre buy oil each year 2020 was $1.99, and this year $2.49 so $1250 a season for oil heat and hot water.
A good HS friend of mine, his Dad was involved with oil-burner research back-when. He's been gone a while now, but he would have spent a week+ going over that Buderus.....
The house I grew up in had an oil furnace. It was OK tech for the day, and later replaced with a (at the time) higher efficiency one.
My Dad would work on just about anything (mtce or repair) but the one thing he paid for every year was to get the furnace burner etc cleaned, being the job that it is....
I'm really curious now about this Buderus - what is the recommended cleaning process and interval ?
Rgds, D.
/ Heating Budget #110
Rgds, D.
A few details - this boiler was mandated in Germany/Europe in the 90's to meet lower emissions, and it has a number of differences to the normal oil boiler. We have a GB125 BE - 87K BTU, three pass boiler with outdoor temp offset control same that is on many newer oil furnaces.
- High Pressure Fuel Pump - 265 PSI
- Heater in fuel line preheats oil before nozzle
- .45 GPH Nozzle atomizes fuel very fine particles
- Air recirculation in burner and outside air intake
The result is a blue flame, virtually no soot buildup, and I clean it spring and fall with a wire brush and vacuum it out. We have 10,500 hours on the boiler now almost 12 years old.
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2019 Chevrolet Silverado 6500HD 4x4 ETI ETC37IH 37FT Insulated Bucket Truck (A59230)
2019 Chevrolet...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Ford 8340 (A53317)
Ford 8340 (A53317)
Ford Pickup Truck Bed (A59230)
Ford Pickup Truck...
