Heating 12 by 20 Insulated Shed
   / Heating 12 by 20 Insulated Shed #21
@WVH1977 I'm not a fan of non-vented combustion heat in enclosed spaces, but that may just be me. There are the partially burned fuel residues, the carbon monoxide and dioxide, and all the water from burning the fuel.
I'd rather seal and insulate the space and then use something simple like oil filled heaters, electric space heaters, or a minisplit. With good insulation and the air leaks removed, it doesn't take a lot of heat or cooling.
All the best,
Peter
Seriously, if it's well insulated, it probably isn't drafty, which means you're burning your breathing oxygen and breathing the burn byproducts. Sounds like a bad idea to burn much in there (be right back, need to turn down the soup on the gas range... but that's a much smaller fire in a much larger space and I suspect a well-insulated shop is better sealed than this house!).
For temporary use get electric heaters, much safer. Long term the minisplit.
   / Heating 12 by 20 Insulated Shed #22
we tried kerosene, ended up being very costly. Got a wall mount LP blue flame heater and it cut cost in half or more. Added a $350 small woodstove and cut heating cost 90% and paid for itself the first winter.
   / Heating 12 by 20 Insulated Shed #23
With the dimensions u have, electric space heater(2) or oil filled have my vote..
   / Heating 12 by 20 Insulated Shed #24
Another diesel heater vote. Route the combustion air from, and exhaust to, the outside. Don't oversize it. They need to run at the upper ranges of capacity to reduce potential clogging of the combustion chamber.
   / Heating 12 by 20 Insulated Shed #25
To the OP, you should also give consideration to what heating method you’re already using for your home.
   / Heating 12 by 20 Insulated Shed #26
I'll jump on with the new diesel heater. I have one heating my 20x20 2 floor cabin, and one heating my 12x24 uninsulated shed. They are pretty much amazing and cheap. I went with an Hcalory brand for both spaces over the Vevor, my buddy has the Vevor and the pulse fuel pump is much much louder and annoying.
The 2 Hcalory units I have are essentially silent aside from the fan and airflow sound.
With the diesel heaters, it is a recommended practice to turn them to full on high heat for 10-15 minutes before shutting down to help burn any soot out of the burner box.
I can run level 2 on both units for about 15 hours on 1/3 of the 2 gallon tank. So around 18-ish hours to a gallon on level 2. I have not needed to run high heat levels yet this year as 38°F has been our lows at night, but I would expect fuel consumption to increase similar to heat levels.
I also did invest in a pair of inexpensive D battery fuel transfer pumps to more easily fuel them up.
In the 20x20 cabin I am using this "fancy version, mounted outside on a shelf I built to window level, and I run only the 3" heat tube in the window through a plywood panel I made. This one, you can just hear the fuel pump if standing within a few feet of it. This has heat settings 1-10.
Then in the 12x24 shed I use this Hcalory unit that is mounted inside and I have the stainless exhaust going out through a marine exhaust bulkhead. The downside to this one is that the burner intake and exhaust come and go from the bottom of the unit, so you need to jack it up on some lumper or find a way to gain clearance under it for the 2 pipes. This one, I can not hear the fuel pump at all. This one has heat settings 1-6.
The second unit also did not come with the 110V to 12V power box, so I ordered it from Hcalory here:
Note that on amazon, you can buy longer exhaust pipes and plenty of other accessories to modify your installation or repair the units. I am real happy so fat this fall with my Hcalory heaters though. We were running old school kerosene heaters and using a CO2 detector, and I was struggling to keep windows open enough to keep readings below 200 PPM and yet keep the place warm. With these heaters being exhausted outside, and the cabin heater mounted outside, I am not getting any readings at all from my air quality monitors. So I feel a lot better about that... you know... the not dyeing thing and all.
   / Heating 12 by 20 Insulated Shed #27
They sell $45 1500w electric heaters that have a built in thermostat and work really well. You may need more than one..maybe not though.
   / Heating 12 by 20 Insulated Shed #28
I think you would be happiest with a direct vent propane wall heater. Empire is an excellent brand, I installed several of them years ago. But cheaper ones are out there, like this one from Ashley Hearth for $202.
   / Heating 12 by 20 Insulated Shed #30
Just a high electric bill
King Kutter Rotary Tiller Tractor Attachment (A51691)
King Kutter Rotary...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
2005 KUBOTA L39 BACKHOE (A51246)
2005 KUBOTA L39...
2001 J ODell 16ft Enclosed T/A Trailer (A51694)
2001 J ODell 16ft...
