Heating 12 by 20 Insulated Shed
   / Heating 12 by 20 Insulated Shed #1
WVH1977
Platinum Member
Richmond, VA
Massey 2860M Cab, Massey 1E.35, Gravely Pro-Turn 560, 1989 Ford D47 Dump Truck
Hello all,
I built a 12 by 20 shed that is fully insluated. I have power to it (6 breakers, 2, 20 amps, 4, 15 amps). I am trying to decide on the easiest way to heat it this winter for around 4 hours a day when it is being used. Not looking to do a mini-split right now. Thinking about a kersosene heater.
What advice/opinions would you have on heating something like this?
Thanks
   / Heating 12 by 20 Insulated Shed #3
The propane option above would work well, or diesel powered heater such as one of these;
Route just the exhaust outside and enjoy.
I got one a couple of years ago to use in my SxS and it works great.
   / Heating 12 by 20 Insulated Shed #5
I would do a mini split. Summer is next. A year round conditioned space is a nice to must have.
   / Heating 12 by 20 Insulated Shed #6
I wouldn't use a kerosene heater unless it's ventilated area
I use to use a Kerosene heater. Then my small room started getting a slimy feel to everything. Plus, it STUNK. And the price for fuel was not even cost effective. I went with an electric spot heater. No stink, no mess.
You can mount it to the wall, or use it as a stand alone. I have it on the wall so it will not get bumped over.
   / Heating 12 by 20 Insulated Shed #7
Last time I bought kerosene, I thought it was expensive compared to other fuels.
   / Heating 12 by 20 Insulated Shed #8
You might try an oil radiator heater. They’re cheap and relatively safe. But you have to leave them on because they take awhile to heat. They will keep a warm room warm if left on, but they won’t warm up a cold room quickly. They are fairly economical to buy and operate.
   / Heating 12 by 20 Insulated Shed #9
This is what I use for my workroom area where I do my reloading and other odds/end jobs. I spend quite a lot of time in there in the winter. Turn it on when cold weather gets here and turn it off in the spring. Built in thermostat keeps it comfortable for working. Also have a small AC window unit for hiding out in hot weather.
   / Heating 12 by 20 Insulated Shed #10
I had one of the kerosene jet engine looking heaters and it worked OK, it requires a special thermostat and you can buy a liquid product that will eliminate the smell. I wouldn't recommend it but it worked OK.
They also have a propane jet engine looking heater my friend had one and it was pretty loud but did a good job.
You can also buy a 120VAC 11,000 BTU window AC unit with a reverse heat pump, I had another friend who had one in a detached shop about the same size shop as yours.
If I was going to buy something today I would buy the AC unit with the heat pump. It is quiet works pretty quick and is an all season unit. If WIFI you can remote start a short time before going to the shop.
377811 (A48836)
377811 (A48836)
2006 VOLVO L110E (A52472)
2006 VOLVO L110E...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2024 Ford F-350 Super Duty XLT FX4 - Like-New, Loaded, Only 780 Miles (A52748)
2024 Ford F-350...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
