Heater for floor of tractor cab?
   / Heater for floor of tractor cab? #1
Sean2202
CT
Kubota L305DT
Greetings,
Curious if any of you have hooked up a heater for the floor of a tractor cab. The tractor does have heat but there are no vents on the floor so operating for the day in sub zero weather your feet get cold. I was considering something simple that can be removed and plugged into the cigarette lighter or a separate 12v fused circuit.
Thanks for any replies
Sean
   / Heater for floor of tractor cab? #2
There used to be all kinds of aftermarket stuff available for the old VW Beetles (air cooled).
If you're wanting to stay with electric heat, you'll want a separate fused circuit to power it.
No way the cigarette lighter circuit would carry enough current to power a heater of any significance.
   / Heater for floor of tractor cab? #3
can buy feet warmers - just like those hand warmers. may be simpler to use on as as-needed basis.
Do you have a good circulating fan in the cab? if not, a fan may help circulate air thru the whole cab better. won’t get it hot on the floor, but will get some warmth down there.
   / Heater for floor of tractor cab? #4
Here's your solution.
Remote control rechargeable heated insoles for your boots.
   / Heater for floor of tractor cab? #6
My cab has a DIY heater and I deflect heat downwards which helps a bit.
My solution was to trim and install custom carpeting that I made up from textured foam exercise matting.
The type that has interlocking 'fingers' and generally sold in packs of 4. and about 1/2 " thick.
Helps a lot!
   / Heater for floor of tractor cab? #9
yeah, 20 amps for just 240 watts.. that's 818.91 btu's.
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
UNUSED JCT 72" HYD TILLER (A57193)
UNUSED JCT 72" HYD...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Bus (A55852)
2000 Thomas Built...
Pig Statue (A55853)
Pig Statue (A55853)
