MossflowerWoods
Super Member
- Joined
- Aug 12, 2011
- Messages
- 5,419
- Location
- Fredericksburg, VA
- Tractor
- Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
OK, I HATE my electric Heat Pump, but I live with 4 ladies and they always think they are FREEZING.
The AC side actually works great, but the Heat side... Good gravy...
It is only 4-5 years old and the finished space is only 1340 square feet. I will need to add a second unit for the attic when I finish it, and the Basement I do open a couple vents in the winter to keep it slightly warmer down there.
Here is my issue. I set the heat to 67 during the day and 62 at night. I need it to be cooler at night so I can sleep.
Every morning for a couple hours the "emergency heat" comes on to warm the house up that measley 5 degrees. We have only gotten down to just barely freezing for a couple hours at night.
Last hunting season, set at 65 degrees, it seemed to run ALL DAY.
Is this normal? Do I call the home warranty company to fix it? What do I tell them is wrong?
MUST I set the thermostat so there is only a 2-3 degree difference?
Also, when I add a unit to the attic I am considering a propane furnace with AC. Can I change out my current Heat Pump "emergency heat" unit for a propane one?
My heating bills are going to be outrageous. almost as high as they were for my 6,000 square foot place in town. There MUST be something I can do...
Thanks in advance,
David
Thanks in advance,
David
