Heat houser
/ Heat houser #1
rdraper
Sharpsburg, Georgia
Kubota L2800HST
I have a L2800 that I would like to put a heat houser on. It has been a cold, snowy winter and operating in the open has been quite uncomfortable. I have looked and nobody sells one for the 2800. They sell one to fit a L 2900. Has anybody put one on a L 2800 and what modifications were needed? Thanks
/ Heat houser #2
Dealer should be able to help,when I purchase my L2800HST it came w/plug in heater.
/ Heat houser
Thomas
I am not looking for a block heater to help starting easier, I am looking for a weather break cover, which is a canvas and frame to help keep the cold off of me
Thanks for responding
/ Heat houser #4
My boo-boo. :confused2:
/ Heat houser #5
Before you make the purchase I suggest you try and fab one up with a cheap tarp or two to see if there is enough heat coming off your engine to provide any warmth for you.
I had a sheet of EPDM roofing rubber I used to wrap around the engine of my British Nuffield 465 which had 65 hp.
There was little heat coming off it until the weather started to get warm enough that you did not need it then the engine would start to overheat.
By enclosing the engine area of the tractor, it got very breezy in the driver's seat as now all the air from the cooling fan was directed back towards the drivers seat. There was no heat coming off the radiator.
Eventually I wrapped the rubber over the rad opening to cut down the breeze.
In WW2 the Americans built a tank destroyer called the Hellicat. It used an aircraft engine with a big fan to move lots of air over the cylinders to keep it cool. I listened to an interview with an old veteran who said they almost froze to death in the tank because of the air moving inside the tank with the cooling fan sucking it in.
Diesel engines do not throttle the intake air like a gas engine does so there is always a large volume of cold outside air being sucked into the cylinders. The more throttle you give the engine the more fuel is injected however, the faster the engine turns the more cold air is inhaled, cooling the engine more.
Naturally you have to be careful not to go too close to the exhaust.
You likely have already considered the soft cabs but I will provide a link just in case.
Kubota L2800 Tractor Cab, Kubota L2800 Cab Enclosure, Kubota L2800 Cab, Kubota L2800 Weather Break, Kubota L2800 Tractor Cabs, Kubota L2800 Cab Enclosures and Kubota L2800 Cabs made with high quality features and materials
My friend who has a B7100 has a cab with no heat at all and finds it tolerable in our cold Canadian climate.
Dave M7040
/ Heat houser #6
Look for Heat Houser Brand.The side entry one for the fords will fit. I bought mine on an auction sale in the bax for 10.00. I had to do very little work to make it fit. I have the L 3301
/ Heat houser
Thanks Dave for the info
When I was younger, we had. JD 4020 and MF 65 both with weather breaks. The JD wood almost chase you out when plowing. We plowed with snow on the ground. I will try a tarp and see what kind of heat or cold I get.
Thanks again for replying
/ Heat houser
Thanks Ivan for the reply-I am sure I won't find one in a auction. I haven't talked to anyone that has put one on a 2800. If the l2900 model would fit and not blow "cold" air back, I would buy it just to keep the outside elements away
/ Heat houser #9
Mine was sold by TSC stores. It has TSC name on it if that helps
/ Heat houser #10
I know this post is almost a year old but I Have a Regal Heat Houser NIB. It is the #1980 which fits many different sized tractors. PM me if interested
2019 NISSAN SENTRA (A62130)
2019 NISSAN SENTRA...
(2) ROW CULTIVATOR W/GAUGE WHEELS (A62130)
(2) ROW CULTIVATOR...
John Deere 8310R Tractor (A64047)
John Deere 8310R...
2015 CHEVROLET 2500 HD CREW CAB FLATBED TRUCK (A62130)
2015 CHEVROLET...
Freighliner Tender Truck (A63118)
Freighliner Tender...
1974 Ohio Body Dry Van Trailer (A64047)
1974 Ohio Body Dry...
