Hear is a Bad Unit
   / Hear is a Bad Unit #2
That's Bad allright!:D
   / Hear is a Bad Unit #3
Interesting to see there is a 3 point hitch complete with top link on the front of that thing. It moves along the road at a pretty good pace, too.
There is getting to be a bit of an issue here in Ohio about tractor speeds and SMV symbols. Supposedly, an SMV equipped piece of machinery is not allowed to go over 25 mph, yet Fastrac, Fendt, and a couple of others will go 45 or more. They are trying to come up with another sign that will let car drivers know the thing ahead of them taking up two lanes is going more than 25, but probably less than 55.
Tractor operators have been ticketed by the Ohio State Highway Patrol for going over 25 in this area. I envision simply putting a round white reflective circle in the center of the SMV triangle as a simple solution to the signage problem -- does anyone else have a better idea for this problem?
   / Hear is a Bad Unit #4
In my opinion that should be illegal. If they want to make a tractor that will do 45 MPH then they should be required to meet all DOT requirements for vehicles. Driving a tractor down the road at anything higher than 25 MPH is not safe and downright careless.
   / Hear is a Bad Unit #5
Probably do not have any in your part of the country but out here we got Freightliner/peterbuilt tractors with a fork lift built on the back where the fith wheel would normally go. they drive those things 75 and 80 on the interstate. Use them to load and unload a 100 bales at a time. It usually follows the truck hauling the hay.But of course is fully licensed.
   / Hear is a Bad Unit #6
Around here Lowes and Home Depot have tandem axle straight trucks with fork lift's that attach to the back. I have also worked on a couple of tri-axle trailers that had them. These are completly different than a farm tractor since they have annual DOT inspections, have DOT numbers, license plates and also have insurance.
   / Hear is a Bad Unit #7
It appears that the tractor is driving on roads in Europe. Rules are much different there.
Jeff
   / Hear is a Bad Unit #8
Wow!
I have always been impressed with the neighbour's Steigher but to see a unit that is hiway capable just blows me away.
Go to there web site and see just what else this company offers.
WOW !!!!!!!
   / Hear is a Bad Unit #9
I'm gonna go out on a limb here and say that any tractor that will run at higher speeds probably has brakes, tires, steering, and so on designed to deal with those speeds. There are too many Fastracs and others running around to believe they don't.
12" x 16.5" Kubota RTV-X1140 Tires (A52377)
12" x 16.5" Kubota...
2012 CASE IH 1230 LOT NUMBER 186 (A53084)
2012 CASE IH 1230...
2020 JOHN DEERE R4023 LOT NUMBER 94 (A53084)
2020 JOHN DEERE...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
