Headlights will not work
/ Headlights will not work #11
Hi,
Any resolution on this? Having the same issue. All lights work except the headlights. Tried ohms meter with the switch on at the headlight plugs and getting no resistance. But when I use a test light at the plug there’s no power. Fuses are good.
/ Headlights will not work #12
Hi,
DeereJohn,
Welcome to TBN.
I'm not sure I understand how you are using your meter. Normally you would us the DC Volts setting to measure voltage at the socket.
You may want to check the wiring from the switch to the light socket. Could be broken or a lose connector.
Richard
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A58375)
2007 FORD F750 XLT...
429981 (A61165)
429981 (A61165)
KMC 6 Row Peanut Reshaker (A60463)
KMC 6 Row Peanut...
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61568)
2016 Volvo VNL T/A...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
MAHINDRA 4540 TRACTOR (A62130)
MAHINDRA 4540...
