Headlights PT425
   / Headlights PT425 #1
tracdoc
Platinum Member
western WA
sold PT-425
OK, if I've used my headlights for a total of 30 minutes since I've had my tractor, I think I'd be exaggerating. Well, when I was putting the PT away tonight, I used my lights and all of a sudden the right one went out. I tapped on it and it went back on, and then it went out again. Tapping again had no effect. I'm trying to figure out whether the bulb simply blew or is something else amiss (faulty ground, blown fuse, etc., etc.). I see only a single wire coming from the lamp housing, and I don't know whether it's fused somewhere and maybe I should be looking for a blown fuse? I don't have a wiring diagram for the PT425, and on 'search' I couldn't find one in archived posts.
Can anyone please help me sort this out? If I do need to replace the lamp, is it the entire unit, or is there some way the lamp comes out of the black plastic housing? Also, if it's the whole enchilada, do I get it from PT or are these available from Tractor Supply or places like that?
Thanks in advance for your assist on this.
   / Headlights PT425 #2
I believe the wire goes from the switch, to the left headlight and then over to the right headlight, but I may be mistaken. Anyhow, the single wire provides + 12V and the ground is accomplished through the bolt that hold the light to the frame of the PT. Loosen the nut that holds the light on and then tighten it again and see if that solves it.
If not, then follow the wire from the lamp and see if the bullet connector that is on the other end is loose, corroded, etc... unplug it and plug it back in again and see if that solves it.
If that does not solve it, swap the bulbs between the housings and see if the problem moves. If it does, the bulb is defective. If the problem does not move, the wiring is still goobered up. ;)
   / Headlights PT425 #3
The ground circuit is through the bolt/nut/washer connection. Snug that down first. If that fixes it, plan on wirebrushing/ scraping the connections soon. If it doesn't work, it's probably a bad bulb.
I replaced my stock headlights with skinny HF foglights mounted to the ROPS. The lights don't get blocked so much by the implements. (I've still got the originals if you need parts).
   / Headlights PT425 #4
Oops! I forgot to answer your question about the bulb and housing. :eek:
The bulb is replaceable. TSC has them. They and a lot of auto stores also carry an entire housing with bulb that is almost identical. I bought two of them and hung them under my canopy. They work better up there than in the factory location as there is no shadow cast by the FEL arms and attachments that way. ;)
   / Headlights PT425
Thanks much for the input and suggestions, guys. As soon as I have another couple of cups of Joe this morning, I'll head to the shed to see what I can sort out. HOW ARE THE BULBS CONNECTED IN THOSE BLACK PLASTIC HOUSINGS?? I was not able to tell in the semi-dark last night --are they threaded into screw sockets, or do you need to pry them out, or?? If I can swap the bulbs side to side, that will tell me a lot pretty quickly.
Looks like VA DOT is swamped or paralyzed at this point. They still have not plowed our street nor the main secondary road to I-81. Lots of vehicles went off into ditches last evening when the wet road froze hard. My plowed driveway is a sheet of ice due to melting snow runoff which froze hard last night. I'll be getting out the salter today--one of those Precision Prods tag-along broadcast spreaders (Tractor Supply, etc.) that I tow behind the PT. The factory made an extended cable for it, so I can turn it on/off from the op seat. Only problem is that I am shy on salt! Dooohhh!
   / Headlights PT425 #6
On my 1445, the housing is a plastic that the bulb snaps into. I bought a pair of replacement housings and bulbs for less than I could buy a replacement bulb.
I wired an SPDT switch, with a center off, instead of the basic switch and then wired a pair of driving lights to the underside of the canopy ahead of the ROPS, giving me lots of light in front for movement, and the option of the factory standard lights for close work, like picking up an attachment.
All the best,
Peter
   / Headlights PT425 #8
... HOW ARE THE BULBS CONNECTED IN THOSE BLACK PLASTIC HOUSINGS?? I was not able to tell in the semi-dark last night --are they threaded into screw sockets, or do you need to pry them out, or?? If I can swap the bulbs side to side, that will tell me a lot pretty quickly.
The bulbs are sealed beams. The black plastic housing is kind of like hard rubber. Just slip a small flat bladed screwdriver between the edge of the lens and the rubber housing and pry the whole sealed beam out from the front. As I recall, there are two screw terminals or push on blades directly on the back of the sealed beam. It may help to take the whole assembly inside and set it in front of a heat duct to get it warmed up and soften the rubber to get the sealed beam out easier.
   / Headlights PT425
Thanks Ponytug and MR for the additional info. After I got the info on the black housing from MR, I was going to remove the entire light assy, but found it hard wired to the switch w/ a double crimp connector and little slack. So, I warmed up the housing w/ hair dryer. When it was softened, I was able to pop the case from around the bezel of the bulb. There were 2 screw/blade connectors on the bulb. After I removed the bulb, I checked out the wiring w/ VOM---light switch ON = 12V reading; light switch OFF = 0V. Seems like it's just a bulb issue, so I'm off to AutoZone, etc. to find a replacement for now.
I would like to add lights up top on the ROPS. There was a post by FOURTEEN awhile back { http://www.tractorbynet.com/forums/power-trac/34740-pt-425-pros-cons-3.html } on replacing lamps w/ halogen 70 watters, and some concerns by TBNers that there may be too much draw so that the alternator can't keep up a charge on battery. FOURTEEN gave a figure of 360 W max, but I'm not sure how this was determined. Is there a rule of thumb as to how much wattage you can add w/o overtaxing the system on a 425?
   / Headlights PT425 #10
You are drawing off the battery, so it would depend on the amount of time you use the lights. Some of the Kohler engines have 15 A, and some, I believe 25 amp alternators, and if so E X I = Watts. So 12v X 25a = 300 Watts. If each light is 55 W, two bulbs will draw 110 watts, and if 70 W, two lights will draw 140 Watts, with some amps left to charge the battery.
15 A alternator
12v X 15a = 180 watts.
Kawasaki NR (A50324)
2016 Nissan Altima Sedan (A51694)
2016 Nissan Altima...
2019 Dodge Ram 5500 Tiger Crane 6545EP 6,500lb 3 Ton 4x4 Crane Service Truck (A51692)
2019 Dodge Ram...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
2025 INDUSTRIAS AMERICA 7014 70"X14' HYD DUMP TRL (A51247)
2025 INDUSTRIAS...
