Headlight shell parts, 2xxx, 4xxx series
   / Headlight shell parts, 2xxx, 4xxx series #1
al3
Central Wi
JD 4110, X500
Never got around to welding some mesh to my grill guard and somewhere along the way something must of hit the headlight. Lens is intact, but reflector side is damaged. Issues is the plastic bracket that screws to the back of the reflector. It holds the ball ends of the headlight adjusters; one side has one broken ball end.
Looked at the JD parts fiche; found the headlight assembly (am120326 ,$55, ouch) but below the headlight line are two other non-illustrated parts, one is labeled LVA 11807 mounting parts Dealer can't help me with a pic or further description. Trying to determine if it contains the adjuster screws (only) or also has the plastic brackets that screw on the back of the reflector shell.
Anyone familiar with the LVA 11807 ?
In case anyone else breaks a mounting tab, here's a straightforward repair. Plastic mounts only available as part of the headlight assembly. Spring is to keep tension on the assembly.
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
MoTrim 3pt. Arm Flail Mower (A50774)
MoTrim 3pt. Arm...
2017 CATERPILLAR 304E2 EXCAVATOR (A51242)
2017 CATERPILLAR...
2013 JLG G9-43A Telehandler (RUNS) (SMOKES) (A50774)
2013 JLG G9-43A...
Volvo 9.5 Cu Yd Hydraulic Loader Bucket (A50322)
Volvo 9.5 Cu Yd...
2014 International Pro Star Semi (A50514)
2014 International...
