Head lights
   / Head lights #1
jdod85
CC 1042
CC LT 1042. Is there anyway to turn off the head lights. I dont need them. Thought about putting them on a switch. Also, to start I have to hold down the break. Again, can I jump this switch and take that pedal off the tractor?
   / Head lights #2
you can put a separate switch on the headlite circuit - yer choice of location.
Don't know about discussing brake sw here... most safety device override discussions are frowned upon by the forum leaders...plus you'll be adding the hydro tranny drag to yer starter load.
   / Head lights #4
I have GT 2554 and I did the same thing, went to Auto Zone picked up a 20 amp flush mounted switch with a pilot light, so you know if they are on or off, wired one terminal to a neutral (for the pilot light circuit) and put a male terminal on one side and a female on the other and just interupted the line going to the headlights that is mounted on the underside of the hood and was done. Maybe it took 15 mins.
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
IH Farmall 706 Tractor (A50514)
IH Farmall 706...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
2016 Ford Explorer...
20711 (A50323)
20711 (A50323)
2016 CHEETAH 40FT CHASSIS TRAILER (A52141)
2016 CHEETAH 40FT...
