Head Gasket Replacement
/ Head Gasket Replacement #1
clifst2310
Bonnieville Ky
Yanmar 2310 and IH 3414 w/loader and 3100 backhoe
I just finished getting my YM2310 running after replacing the head gasket./w3tcompact/icons/grin.gif Because it has 597 hours I also adjusted the valves, cleaned the radiator inside and out, cleaned the fuel tank, adjusted the throttle tensioner, checked the steering box, changed the fuel filter and fuel lines where needed, replaced the fan belt, replaced the air filter. I also fixed a support that was preventing me from using the clutch lock. I also was able to fix the starter interlock so the tractor can't be started with out the clutch ingaged. I got the parts I needed from Len Sheafner, he was extremely helpful. Now the interesting parts. My clutch was stuck, but the tractor was only down for 3 weeks. /w3tcompact/icons/crazy.gif I was able to free the clutch by locking the clutch down and driving the tractor while hitting the brakes. After stalling a couple of times it freed up. I bleed the fuel line between the tank and injector pump with no problem. I had a hard time bleeding the three injector lines because the starter motor needed to be rebuilt. It was turning the motor over too slow. I spent almost a week trying to get the lines bleed and the tractor started. /w3tcompact/icons/frown.gifOnce I fixed the starter the lines bleed right out and the tractor fired up. I have both the maintenance and operators manuals, and I couldn't have fixed everything without them. The starter problem I resolved after reading the chapter on starters. I also got alot of help from you guys./w3tcompact/icons/king.gif I had previously read all the posts at the old club and was able to reference problems I was having by looking here at TBN or looking up old posts there. The bleeding posts were really helpful as this turned out to be the biggest problem I had. My thanks to everyone who has taken the time to answer questions here or there, /w3tcompact/icons/clever.gifwithout actually having to ask one all my questions were answered by you all. This site is really a tractor saver at times
/ Head Gasket Replacement #2
Where do you live? Sounds like you are ready for a part time job. bw
I live in centrel Kentucky, close to Tom Fredicks dad. ( I got my Yanmar from Tom's dad.) I enjoy working on older vehicles. Before the headgasket, I fixed up a 79 ford 3/4 ton shop truck, and my next project is a 59 ford f-600 dump truck. I',m also rebuilding a 50's era small ranch type farm house. Keeps me busy as I'm retired military. I also maintain my 91 HD and have rebuilt a couple of british bikes in the past. There is no better way to learn than an older vehicle, good techinical manual, some good advise when the manual doesn't cover a particular problem.
/ Head Gasket Replacement #4
Clif, you kind of remind me of myself, retired cash register mech./computer tech. (33 yrs. NCR Corp.), except I don't have any degrees. Overhauled several British motorcycle engines as a teenager, a 500cc Matchless single, a couple of BSA singles, and 3 or 4 Triumph 650 twins. Was a smallarms tech. in Army National Guard for 6 years. Currently refurbing a 70 year old cash register just to keep around after they are all gone.
I've done a 69 tiger, 79 bonnieville and helped a friend do a 67 BSA. I was a enlisted combat engineer and after my commission I ran a explosive ordinance disposal (EOD) unit. Did 6 months in SWA with alot of disposal work during and after Desert Storm. I enjoy wrenching and working with wood, to me it is relaxing. I've got 3 acres here and spend time upgrading the place. The dump truck I got for $200, it is all there but needs alot of TLC. I want to use it to move a couple hundred yards of dirt from the back to the front of my property.
John Deere 400 (A64119)
John Deere 400...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2013 Ford Escape SUV (A61574)
2013 Ford Escape...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A63276)
KNOW BEFORE YOU...
