Head gasket pop!!!
   / Head gasket pop!!! #1
murrayDK45
Kioti DK45se HST
Hey everyone
First post . I have a 2007 Open station DK45se HST. Awesome tractor. 1145 hrs. @ 600 hrs fuel pump crapped out. I was told they don't rebuild the old ones u need to by new so I did. $1200.00
Then I did the work my self , no warranty left on the tractor. Replaced the pump. Then looked at the old one found a chipped tooth on the plastic gear. I tooled it apart turned it 180 put it back together works fine.then I find out the pumps can be rebilt
   / Head gasket pop!!! #2
By rebuilt, do you mean they can be disassembled and reassembled or do you mean there is a source for parts? IPs have close tolerances and I understand they are lapped as matched sets.
Also, I assume your gear rack was undamaged?
   / Head gasket pop!!! #3
Muray...I'm confused...so is your head gasket blown? If so, it's not a big deal to fix, just make sure your replace the bolts too, not just the gasket.
2024 CATERPILLAR 255 SKID STEER (A51246)
2024 CATERPILLAR...
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A52472)
2012 TEX MEX...
2012 Kenworth W900 (HEAVY DUTY) (A52748)
2012 Kenworth W900...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
