head gasket on 1085
   / head gasket on 1085 #1
sticky
Northwest Indiana
I need to change the head gasket on a 1085 and was wondering how hard it is and how long it will take? The tractor is in the middle of nowhere and can't be hauled in. I have a head gasket set should I give it a shot?
   / head gasket on 1085 #3
A 1085 has a 318 Perkins, the early ones had, head bolts, and were later changed to, head studs with nuts. The early ones were prone to blow head gaskets and this is reason for the change. When the head gasket is changed the surfaces have to be correct or you will loose the gasket again. If you have the early style, head bolts, they can be changed to the studs with nuts.
Chuck M.
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
2020 Toro Workman HD Gasoline Utility Cart (A50322)
2020 Toro Workman...
2012 Ford Explorer (A50120)
2012 Ford Explorer...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
Scag Zero Turn (A50121)
Scag Zero Turn...
