Head Bolts 1910
   / Head Bolts 1910 #1
simonmidvt
I have a ford 1910. i need to replace my head gasket $50 Do i need to replace my head bolts too?? $150
   / Head Bolts 1910
please any "i have and it worked" or "i have not and wished i did"
   / Head Bolts 1910 #3
Sorry cant help, but.
$150 for head bolts seem high, but then again I've never bought any, especially for a diesel. Seems to me they are just bolts of the right size and length.
I'll be curious what is said here.
Wedge
   / Head Bolts 1910
does anyone have any info on this? should i post this in another spot on this site? Please help.
   / Head Bolts 1910 #5
I am by no means an expert, but I believe that head bolts on engines are designed to stretch a certain amount with the proper torque, and are a single use item. I would go to a good auto parts store or a trusted auto mechanic and get their opinion.
   / Head Bolts 1910 #6
It's little sister, the 1710, uses studs and bolts for the head.
While 'torque to yield' head bolts are used on some motors, I don't believe this is one of them. Their use is more within the last decade.
The 1710 service manual describes the normal step torque and cross pattern technique for reattaching the head, not the process for 'torque to yield'. Consequently, the bolts and studs can be reused unless there is some thread damage.
   / Head Bolts 1910
Thank you that is what i had come up with for an answer. Any others to sway me the other way but 150$ for 14 bolts is a little much.
   / Head Bolts 1910 #8
Clean and lubricated the old bolts before reuseing.
Bill
   / Head Bolts 1910 #9
I thought torque specs were for dry clean threads...
Jim
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A53473)
Kuhns AE10 Small...
1992 MACK RD688S (A53843)
1992 MACK RD688S...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
