head bolt retorque
Status
Not open for further replies.
/ head bolt retorque #1
Amez
BC,Canada
Jinma 284
Does anyone know if a 50 hour headbolt retorque is required on a 2007 Jinma or do they have multi layer steel gaskets (or torque to yield headbolts)? The manual says nothing about it.
/ head bolt retorque #2
Hello ! I would check the head gasket that came in your parts kit. The one on the tractor and the one in the kit should have come from the same bunch.This was is not 100% sure but a good start. Good luck ! joe
/ head bolt retorque #3
Regardless of the gasket material, I don't think confirming/re-torqueing will hurt anything. Then you at least know the status of the head bolts/studs... When I did mine, I found and removed quite a bit of machineing debris in the head when I removed the rocker assembly to accomplish the retorque.
/ head bolt retorque #4
Yes,
And yes, Hope the attachement works. It took me abbout and hour to complete. I did mine at 73hrs. Set clicker torque wrench to 105ft/lbs. Nothing budged. So at least it was torqued properly at the factory.
YukonKing
JMretorque
/ head bolt retorque #5
Not necessarily true. What if one or more of them was torqued to something in excess of the factory spec? Or maybe undertorqued - but rusted in place? Without loosening them before resetting torque, you'll never know.
I know Mike Stuart's document says it's not necessary to loosen first - I simply have a different opinion.
//greg//
/ head bolt retorque #6
//greg//
I'm on Greg's side. You'll never know what you had unless you undo it. This is what Caterpillar used to recommend.
In some cases it is impressed upon to see what the "break-loose" torque is/was, wherein you use a dial torque wrench set to zero then take the "break-loose" value for reference. Although this practice is reserved for multi-million dollar engines where you must have a BS just to change filters, it won't hurt a thing.
/ head bolt retorque #7
Mmmm,
Fair enough, but the recommendation is to not loosen. Even though they may have been over torqued at least it wasn't leaking up till now. (aint broke don't fix it). But I would think you are risking things moving. In my opinion if your breaking them loose you should be replacing the gasket. Plus when they were initially torque beeing brand new, assembled with lots of oil, now after many heating and cooling cycles with the oil drying out a bit they could actually require more torque to break them than when they were put in? An extreme example is any old hardware on most vehicle, say 10 years old... it usually takes more to break them than when they were new? I realize that 50hours bathed in oil is not the extreme but maybe? Anyhow i'm sure either way I will get many more hours out of my little Y385 diesel.....I hope.
So what is the correct way...........? Heck if I know.
YukonKing
Either way I am very impressed with these Engines/Tractors up till now.
/ head bolt retorque #8
Hey YukonKing,
I am not on Greg's side but, I recommend breaking the head bolts loose for a retorque and have done so for many years. It has been a general practice in my field. I would never oil the threads unless you have a wet thread spec.
As of yet these engines do not have torque to yeild head bolts.
Ronald
Ranch Hand Supply
/ head bolt retorque #9
hey,
no worries, the more opinions, ideas and information the better. the only reason I offer my opinion is because I bought a tractor. if i haden't I wouldn't be on here.
but the question remains should he retorque? I think yes.
P.S. Its spring here I have 8 inches of mud around the house i'm building and living in.
peace
/ head bolt retorque #10
If you want to do it the correct way, remove each bolt one at a time (in sequence), clean and oil the threads (most torque values assume clean oiled threads and head seat) and then re-torque to 2/3 of the final value. When you have completed that, then torque to the final value (in sequence).
It seems kinda **** retentive for these engines, but you asked.
Head torque trivia
On the RND Sulzer engines, the "head studs (about 4-1/2" dia.)" go all the way down through the crank bearing caps (approx 22 feet); the nuts are spun on hand tight and then "pinged" with a slugging wrench. All that while under 12 tons of hydraulic jack tension. Six at once.
Fuel injection trivia:
The RND is a two-stroke diesel engine. Every time the injector "pops", there goes ~85 gallons of HFO.
Enough; back to tractors.
/ head bolt retorque #11
If you do decide to crack the bolts before re-torqueing make sure you drain the radiator first . I have seen water in cylinders and in the oil by not doing so as the head can lift a little when you crack the bolts .
/ head bolt retorque #12
Good recommendation, although in my experience I've only found it necessary to drain enough to drop the coolant level to just below head gasket level.
//greg//
/ head bolt retorque #13
YukonKing said:
hey,
peace
Should he retorque - Well if the manual says to then so be it. I would probably not. I've rebuild several hundred diesel and gas engines and have never done this. It was not receommended in the manuals. When I replaced the head gasket on my Kubota I did not recheck. After some discussion here and double checking the manual, it DID say to retorque after a couple hours. But I did not do this and still haven't done this. Call me lazy I guess.
A question is should you loosen then retorque. I would not do this BUT if you wanted to and did one bolt at a time, yeah maybe. I would not loosen all of the head bolts then start over. Even if you drain all the water some still will be hanging around in the jackets and could comtaminate the gasket. Same goes for the oil returns. Plus IMHO, once you crush a head gasket, it should be replaced.
Then you get into the headbolts themselves. Do you know if they are a stretch bolt or not? Some OEM's say to replace certain bolts after they have been torqued. When I replaced the head gaskits on my Son's mustang Ford says to replace the bolts. I hated to but I did. In the engines I rebuilt many bolts were speced to be replaced.
JMHO yall,
Rob
Status
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
2020 Komatsu PC210LC Hydraulic Excavator (A64553)
2020 Komatsu...
2011 Mini Cooper Countryman (A64557)
2011 Mini Cooper...
1999 INTERNATIONAL 3900 4X2 S/A WRECKER (A67148)
1999 INTERNATIONAL...
2022 Kubota SVL75-2 High Flow Compact Track Loader Skid Steer (A64553)
2022 Kubota...
