HDS2135 Brake safety switch
   / HDS2135 Brake safety switch #1
OldGeezer68
Pa
Wheel horse & cubCadet
I have a HDS2135 Cub , it just started acting weird . If it's running I should be able to put on the parking brake and get off the tractor as long as the pto is not engaged. Well now it will keep running as long As I'm on the seat ,but if I put on the brake to get off it stops. Kind of a pian if I need to stop and pick up a branch or such. I've figured it almost has to be the safety switch tied to the Brake. Short of rolling the thing over I can't see where that switch is? Crawling around looking don't go as well as when I was younger. Anyone can help me out here would be great.~~OldGeezer68
   / HDS2135 Brake safety switch #2
Your model has a safety cut off switch under the seat. I believe all 2000 series tractors do. I disconnected mine so when I'm not in the seat it stays running. Probably not the safest thing to do be. The seat cut off switch is easy to disconnect. Good luck.
Kivel Hay Spear (A50121)
Kivel Hay Spear...
2012 Ram 4500 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ram 4500...
Loader Bucket (A50322)
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
CFG Industrial QK18R (A50121)
CFG Industrial...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
