HDAP vs R4 tires
   / HDAP vs R4 tires #1
erieskidoo
Erie, PA
John Deere X728SE
Have a X728SE and was pondering on switching over to the R4 Trac Chief tires. Has anyone here done this? Pics? And what are your thoughts. I have mainly flat land that I mow with one sharp hill - grading on the north side of my house. I also do quite a bit of snow blowing around the neighborhood with some driveways on hills.
   / HDAP vs R4 tires #2
I would stick with HDAP's for the uses you have specified. R4s will do no better than HDAP's on the hill and HDAP's will perform better in the snow. Just my :2cents:
   / HDAP vs R4 tires #3
I can't see any advantage to switching to R4 tires on your mower. This year I pushed 12" of snow with the hdap tires (no chains or wheel weights) with no problems at all.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2014 MACK GU713 WATER TRUCK (A54756)
2014 MACK GU713...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
10 - 3/16in Plate Steel Sheets (A52377)
10 - 3/16in Plate...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2021 Exmark Lazer Z 60in Zero Turn Commercial Mower (A52377)
2021 Exmark Lazer...
