Hazard Flashers won't go off
/ Hazard Flashers won't go off #1
ctcyclist
Kubota BX23
Hi,
I have a BX23, and the flashers will not shut off. I washed my tractor a couple of weeks ago, no power-washer just a garden hose, and afterwards the flashers just started doing their thing. I had to disconnect the battery to stop them. Can someone tell me what might be causing this?
Thanks,
Rob
/ Hazard Flashers won't go off #2
I'd start with replacing the switch.
Cheap and easy.
/ Hazard Flashers won't go off #3
I have had this happen a couple of times an my BX24 ( I assume it's the same switch, or similar) - either stuck on or have to "wiggle" to get them on.
There is a spring loaded contact in the switch that seems to corrode easily causing the issue. When you rotate the switch, contact does not move correctly and spring just stretches
I have basically pulled the switch apart, cleaned the contact and spring, lubricate and reassembled. It actually just went on me today again out in the snow. I'll take some pics this time
If you attempt it - beware of the small pieces - best to work on a table with good lighting
/ Hazard Flashers won't go off #5
Cheap and easy.
I originally intended to to this, so decided to pull it apart. As nothing was broken, just a corroded contact - I figured buying the $50 replacement part would eventually develop the same issue
/ Hazard Flashers won't go off #6
$50 for a switch?
I'm not familiar with the machine and assume any common on/off toggle would be fine.
I guess I'm wrong.
Spent $2 a piece on my light switches.
/ Hazard Flashers won't go off #7
Buy a $2 toggle switch.
Replace.
That would work as well - but a little more involved since it is a combination switch assembly (headlights, turn signals and hazards) - splicing or running new wire, adding new custon toggle to the panel board, etc
The attachment below, Reference # 30, shows the switch from the BX24
Part number is K2581-62240
  • BX24D.pdf
One thing I forgot to mention is that if I turn the hazard light switch on, then off, the flasher stay off for about 15-30 seconds, then they start flashing again.
Rob
/ Hazard Flashers won't go off #9
I was wondering which switch was worth $50.
I'd take a shot at repair as well for those buck$
/ Hazard Flashers won't go off #10
Rob
It could be more than the switch - but with the spring - there is some play with the switch - wiggle it around, lift up and/or push down to see if it breaks the circuit, even if temporarily
I'll probably buy a new one then fix and keep the old as a spare - will enable a 30 second swap out. The "fix" only took about 20 minutes - and that was out in the field
/ Hazard Flashers won't go off #11
Mine does the same thing after I wash it if I get too much water on the dash. Just take the rad screen of and pull the wires to the hazard switch for a day...It'll dry out and be fine.
Keep meaning to find a water proof switch for mine, but this is such a rare occurance, that I forget about it.
/ Hazard Flashers won't go off #12
I know this is a common problem, & I think I read somewhere that the replacement switch from Kobota is re-designed to correct this problem. Seems like that should warrant some sort of recall...
Thanks for all the advice. I'll probably start with disconnecting the wires from the switch first. If that doesn't work I'll try disassembling the switch. And if all else fails I guess I'll buy a new switch.
Rob
/ Hazard Flashers won't go off #14
Rob
Biggest thing that I've found is don't soak the dash when washing...Light misting doesn't seem to cause this problem...First noticed this in 2004...Had the problem once since then..Live and learn, I still have the OEM switch.
/ Hazard Flashers won't go off #15
Thanks for that link to the previous post. It made me reconsider my plan. Why bother taking the Kubota one apart, when I can buy a better one for about $8.00. I'll probably head over to a local marine store with my switch, and match it up with a marine grade one. Why O' Why would Kubota mount non-marine grade switches on there tractors knowing that there is a high probability they will be used in adverse conditions, stored outdoors, or heaven forbid... washed.
Thanks for everyones help! It is much appreciated.
Rob
/ Hazard Flashers won't go off #17
This is an old and continuing problem. Many dealers have problems with units on the lots, not just Kubota. Kubota has changed the design on some models and upgraded, I changed a switch out for a friend a month or so ago and he hasn't had any problems since the change, his tractor stays outside. Before the change his flashers would just start in the middle of the night or anytime, he kept the main fuse pulled until he purchased a new switch.
/ Hazard Flashers won't go off #18
You are correct: Wasing the tractor caused the OPs problem.
2013 29ft. Larson LXI292 Boat with 2007 30ft Loadmaster T/A Boat Trailer (A64557)
2013 29ft. Larson...
2011 Tri Axle Frac Blender Trailer (A64194)
2011 Tri Axle Frac...
(26) Mineral Tubs (A66408)
(26) Mineral Tubs...
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
2021 JCB 35Z-1 Mini Excavator (A64553)
2021 JCB 35Z-1...
Corral Walk-through Gate (A66408)
Corral...
