Haying when wet
/ Haying when wet #1
dorper2
North Okanagan
Kioti NX 5510 HC & Kioti CK 2610 H
Long time watching this form but just signed up.
I have a question for any one that has a hard time getting the windrows dry enough to bale when the rain is threating. Can I use a spot sprayer to apply a chemical preservative so I do not lose a whole round bale when parts of it are too wet? Is there one preserver that is better than another?
/ Haying when wet #2
I run a Harvest Tec applicator built into the round baler. Don’t know how youd spot spray...
Mine comes on automatically when it sense moisture over a preset amount, like 16%.
/ Haying when wet
Thanks for the info.
I only hay about 8 acres twice a year with a small twine wrap round baler so it probably would not pay to try to adapt an applicator to it. I am looking for a cheap way to (manual spray can?) to hit problem spots when I know them to be too wet. Has any one tried this?
Thanks for your help.
/ Haying when wet #4
I don’t think that will work as well as you want it to. And if it doesnt and you store hay inside, the results can be catastrophic
/ Haying when wet #5
If it was me, 8 acres twice a year I would wait for good weather, less stressful then putting up damp hay. I've rushed damp stuff and let the bales sweat outside for several weeks, but wasn't worth the constant worry the bales were going to combust.
I'd invest in a tedder if you don't already have one, speeds up your drying and "mixes" the hay so the damp spots dry evenly. A two rotor would go over 8 acres in a couple hours easy.
My record for baling dry hay was 8 hours after mowing (30C day on dry ground and 30-40k wind blowing) Tedder turned the swaths to ensuring top/bottom dried evenly.
I'm feeding some of those bales right now, nice hay.
My real weather beater? Since I am doing the acreage with smaller gear and can't always get all the hay done in the narrow weather windows...I bought a bale wrapper.
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
2005 INGERSOLL-RAND SD-116F TF  ROLLER (A67147)
2005...
2022 WACKER NEUSON G25 TOWABLE GENERATOR (A63276)
2022 WACKER NEUSON...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2003 Ford E-450 Super Duty Passenger Bus (A61573)
2003 Ford E-450...
JOHN DEERE 1705 - 6R36" VACUUM PLANTER (A64278)
JOHN DEERE 1705 -...
