Haying On Shares...What's Customary
   / Haying On Shares...What's Customary #31
I'm not sure why everyone keeps saying the owner "gets clean fields". I'm not talking about ditch hay, I'm talking about tillable acres, put into hay / alfalfa for a crop. Of course the deal would have to exceed the 300 dollars per acre rent that we get for doing nothing.
If we put in all the work and all the expense and take all the risk and the landowner just wants to collect a check it's worth about $15-20/acre. Most people with 5or 6 acres will tell you not to worry about the $100. It's not ditch hay. It's mainly grass hay with some legumes. Now it's not alfalfa but good beef cattle hay.
If your getting $300 for renting out row crop ground don't even bother with hay. It can't touch row crops if all you want is the money.
I guess things are different in KY. A good portion of my row crop land is already hay. I'm just thinking about doing it in shares instead of just renting the land out. Good hay is very profitable here in MN. I need quite a bit of hay for my beef cattle, and get tired of renting out land, then buying hay back. I suppose the real answer is to tool up and make my own hay, on my own land.
   / Haying On Shares...What's Customary #33
We bale 86 acres on halves every year. We do half in round bales an half in square. We have never felt cheated an the land owner is very happy to have hay for this cattle.
I'd be happy with halves. If I seed, spray and fertilize 70/30 doesn't make a lot of sense.
   / Haying On Shares...What's Customary #34
. . . If your getting $300 for renting out row crop ground don't even bother with hay. It can't touch row crops if all you want is the money.
+1
That's what I'm thinking.
   / Haying On Shares...What's Customary #35
If ourlandowners do that it is a 50/50 split.
Have seen some go 1/3 landowner and 2/3 baler. But man that is hard if landowner is giving any inputs.
   / Haying On Shares...What's Customary #36
You're getting at the bottom line -- what is it worth to the hayer? Some portion of that is the most the landowner can expect to receive. That number is going to depend on a few other numbers, which vary tremendously by region. The first is the innate productivity of the land. The second is what it costs to take hay from it, including all inputs. The third is the market value of the hay.
Costs and market value are determined by local market conditions. To answer the question for yourself, you have to do some research about the local market. Answers from the rest of the country may be interesting but they're really not of use to you.
Just for curiosity's sake, I'll tell you about how things are in Rhode Island. I have nine acres of hayfields. Grass grows like crazy here, it's the dominant weed. My land used to be a sod farm, it's well watered and rich soil. I have someone come in and cut it once a year and that's all I do. No seeding, no irrigation, no fertilizer.
Last year the guy who cut it got 56 800-lb bales. That's 22.4 tons, or 2.5 tons per acre. He sells those bales on Craigslist for $40 each. That's $100/ton, or $250 acre, or $2240 for the whole cutting. I don't know what it costs him to cut it, but what I have observed is:
1. It takes a not insignificant amount of time. It's a minimum of four trips around the field to cut, tedder, rake and bale, more if it rains. Each trip is about four hours. Plus the time to truck all the equipment in and out, and gather the bales and truck them out.
2. It takes a not insignificant amount of equipment. In the course of the cutting I'll see:
* A disc mower
* A tedder
* A rake
* A baler
* A tractor to pull the mower
* Another tractor to pull the rake and tedder
* Another tractor to pull the baler
* A loader/backhoe to gather the bales
* A flatbed truck to haul the equipment and the bales
3. I've had several different guys do it, and they all seem pretty indifferent about whether they do it or not. Some years I haven't been able to find anyone to do it. Any suggestion on my part that I get anything out of it quickly ends the conversation.
If I had to guess, I would say that all told he nets about $1000 per cutting and puts in 40 hours beginning to end. That works out to $25/hour, which is less than I pay the guy who cuts my grass.
* A disc mower
* A tedder
* A rake
* A baler
We get over 4 tons to the acre, and it goes for up to 180 bucks a ton, more if you sit on it till spring.
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
Electric tri scooter irgc40 (A56859)
Electric tri...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Generac XG8000E Generator (A55973)
Generac XG8000E...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
2022 Kubota RTV-XG850 Utility Cart (A56857)
2022 Kubota...
