haybine hydralic hook ups
/ haybine hydralic hook ups #1
blaze 57
Bronze Member
I'm looking at a New Holland haybine...problem for me I have no rear hydralic hook up ports. I do have a loader with the quick disconnects. Could I use like the bucket "curl" port to hook the haybine hydralics?...thanks
/ haybine hydralic hook ups #2
I think it could be done. I would look at adding rear hydraulics though. They are alot more convinient to hook up.
/ haybine hydralic hook ups #3
It will work . i did it for years with a john deere where rear ports did'nt work so ran extensions fron loader ports in front of cab :)
/ haybine hydralic hook ups #4
Yup. Make your extensions & route them really good & out of danger and you can just leave them on there when you're not using them. Haybine won't care where the fluig comes from. We do this with a compact we have to run the lift on the Tedder & Rotary rake. Way cheaper than the Aux. setup.
thanks for the replies!!...looks like a go then. This will save me some $$ if I dont have to add rear remotes.
24in excavator tooth bucket (A61307)
24in excavator...
2019 Chevrolet Ambulance (A60352)
2019 Chevrolet...
New/Unused Quick Attach Auger with Three Bits (A61166)
New/Unused Quick...
2012 Peterbilt 386 T/A Day Cab Truck Tractor (A60352)
2012 Peterbilt 386...
2015 International TranStar 8600 T/A Day Cab Truck Tractor (A61568)
2015 International...
2013 TEREX USA LLC LIGHT TOWER (A60736)
2013 TEREX USA LLC...
