Hay Sweating in Barn (moisture gain)???? Normal?
   / Hay Sweating in Barn (moisture gain)???? Normal? #1
powerscol
SW Colorado
CT 235
I baled my hay Saturday at 7 to 14% moisture (most reading in the 8-12 range). I happen to break a bale open today , Wednesday) and found it felt damp. Grabbed the moisture meter and it now runs from 16 to 25% in the stack in the barn :eek: I checked each bale several times. Is the normal? Am I in for trouble?
Thanks for any help.
Keith
   / Hay Sweating in Barn (moisture gain)???? Normal? #3
Never used a moisture meter, but if they feel hot, let them breathe somewhere. Heat means too damp/wet and will catch fire if too severe..
   / Hay Sweating in Barn (moisture gain)???? Normal? #4
Hay is not gonna pick up 10 points in the barn. If it is warm and damp, you are getting true readings now. Move the hay out.
   / Hay Sweating in Barn (moisture gain)???? Normal? #5
I disagree. I've rd baled hay at or below 15% moisture checked by my Delmhorst moisture tester then checked again the next day with bales still in the field and moisture % would be in the low to mid 20's %. The 15% moisture in the hay at baling causes hay to heat a little creating a slight sweat making moisture content in hay rise.
   / Hay Sweating in Barn (moisture gain)???? Normal? #6
Smell the hay. A moisture meter is great but I can usually tell by smell if its to damp.
   / Hay Sweating in Barn (moisture gain)???? Normal? #7
This is not a complex issue. 14% or lower hay will not pick up 10 points of moisture while stored in the barn, nor will 14% or lower hay heat appreciably in the barn. You guys can argue about this forever, I'm done here.
   / Hay Sweating in Barn (moisture gain)???? Normal? #8
Your moisture meter only read the surface of the stems, not the interior level. So, the high interior content has bloomed out to the stalks. Your hay is gonna mold. Check your moisture meter by 1) hitting the cal button, and 2) measuring the level of your hands. I forget the exact number but its usually maybe 18 - 19% ???
My rule is that you should be able to hear the hay as it passes up from the feeder tines. If its crunchy, its DRY. Does your mower have condition rolls? If not, now you know why they are an important part of the hay preparation process: cracking the stems to let moisture out.
   / Hay Sweating in Barn (moisture gain)???? Normal? #9
Bale it, but don't stack it tight in the barn till its has set a day or two. Check for heat, then put it away.
Those open frame hay wagons, with the bales tossed in off the baler kicker are handy if you aren't putting up more hay than you have trailers ;-)
   / Hay Sweating in Barn (moisture gain)???? Normal? #10
Who is arguing???
Don't let the door hit your huge head on the way out.
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
ECONOLINE TRAILER, INC (A50323)
ECONOLINE TRAILER...
2018 POLARIS RANGER 570 EFI UTV (A51247)
2018 POLARIS...
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
