Hay Ring advice needed
   / Hay Ring advice needed #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
Three years ago I bought a Priefert Tombstone feeder for around $240 that I really liked. It worked perfectly and I thought at the time I bought it, that it was a good one. It was the most expensive one that they had.
Tombstone Feeder
Last year it started falling apart. I used the smallest welding rod that I had and sort of put it back together. Now it's so rusted out that there is no hope for fixing it. After just three years, I'm a bit surprised at how quickly if failed. The tubing is very thin wall, and the paint is probably the bare minimum. So that was a waste of money that I will not repeat.
I have horses and I like the design so they can get to the hay, but it keeps them from walking all over it.
I need to find something else, but in just looking online at the different stores in my area, they all sell basically the same thing. I haven't gone in person to look yet, but will this weekend. My next option is to drive around to different feed stores and see if they have anything there that might be heavy duty. There is also an ad on Craigslist for a guy that builds them, but they look kind of flimsy from the pictures posted. I might go look at them in person to be sure.
Who has a really good, heavy duty round bale hay ring for horses and where did you get it?
Can you post a picture or a link to what a really good hay ring for horses looks like?
Thanks!!!
   / Hay Ring advice needed #2
My neighbor has three that have been out in the field with cattle for years, but I have no idea where he got them. Maybe TSC?
He also has a poly trough feeder with metal legs that have completely rusted out to dust.
   / Hay Ring advice needed #3
If they offer more than one model and that is their best,I'm surprised to hear it failed. Could it be that being light weight and easy to move account's for price? The rings we use for cattle are so heavy they can't be easily dragged so we tilt and roll to move. I would talk to Priefert to see if their cheaper model is heavier. I've known the family for years and believe they will do what's required to help you get what you need. If they don't have thicker or solid tube,maybe they will use tube you furnish to construct your ring. You might also ask if you pick up heavier tube or solid bar at Greenville Steel if they will bend it so that you can fabricate one yourself. If all that fail's,ask Greenville Steel to recommend a fabricator or just buy material and build it yourself. I can't remember his name but there's a first class young man from Celeste that opened a welding shop in Sulphur Springs 2 or 3 years ago.
   / Hay Ring advice needed #4
I don't think you will find any of them of heavy gauge material. Hay rings made from lightest gauge metal made and laying around in cow poop and urine are going to rust out very quickly. If I wanted one that would last, I would get a fab shop to bend some angle iron to the required diameter and build it out of that. OR you could just build it in an octagon shape or even square if you are going to always more it with your tractor.
I would elect to use an octagon shape to avoid the sharp corners and avoid the cost of having the metal bent.
   / Hay Ring advice needed #5
The poly ones they sell for cattle are supposed to be the very best with some folks saying they are 5 + yrs old and still look like the day they bought them. If the horse is not smart enough to figure out how to eat out of one I would say sell the horse.
   / Hay Ring advice needed #6
Don't use the poly cattle style for horses, they will rub off a lot of their mane on the top rail.
Cattle style:
This is the poly horse bale ring that we have used for over 7 years:
A better view of the 8 foot diameter horse style poly bale ring:
   / Hay Ring advice needed #7
As clever as you are Eddie, with a little thought you could come up with something better than anything on the market. The toughest part could be finding the time to do it.
   / Hay Ring advice needed #8
Exactly what I was thinking. :stirthepot:
   / Hay Ring advice needed #9
Go Bob Pipe and Steel Sales is a place to look they make things like you are looking for if memory serves me correctly
   / Hay Ring advice needed #10
Try J&L haysaver feeders in PA (814) 893-5086. They make very heavy feeders. I have one for cattle but they also make one for horses.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2002 Olympian Generator (A52377)
2002 Olympian...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
90018 (A48082)
90018 (A48082)
Scag STT61V 61in Zero Turn Mower (A51694)
Scag STT61V 61in...
