Hay rakes
   / Hay rakes #1
xmariner
Bronze Member
Bushnell, FL
LS XR4155HC
I know this is a matter of personal preference but I'd like to "hear" your thoughts on wheel hay rakes vs rotary rakes. I realize that wheel rakes can come in very large configurations for obvious reasons.
We hay between 8 and 15 acres so it's small enough to consider both.
   / Hay rakes #2
What you growing? What type rotary rake you looking at? I have the WR22 and wish would have gotten the Kuhn speed rake or like.
   / Hay rakes #3
I learned the hard way that you REALLY have to look at the potential for breakdowns. Get the most simple, high quality tool that you can afford. I started with a rolabar rake, and I've sunk a good bit into it, just in u-joints and rubber teeth. And still had it fail while taking, with a storm coming. I hear that the rotary rake doubles as a tedder. While it sounds like a good idea, I think it's better to have that as 2 separate tools; if I'm using my tedder and it breaks, I still have my rake to finish up the job.
   / Hay rakes #4
I've never had a "wheel rake", but did own a very old IH No. 5 side delivery and that thing roped the hay. I bought a Morra rotary from Agri-supply and really like the fluffy wind rows it made. I tried to ted with it and it still gpt kinda of a wind rowed. My vote is for the rotary rakes. bjr
   / Hay rakes #5
We use a wheel rake on 70 acres of coastal bermuda hay. JD 10 wheel rake which is a really a Tonutti. Simple and inexpensive piece of equipment.
   / Hay rakes #6
I'm using a IH16. Doesn't seem to rope the hay. Had to replace a couple of bearings and some teeth but otherwise pretty good rake
   / Hay rakes #7
I like the parallel bar like the JD 600 series. Just work for me regardless of the crop. However, I don't do the work that makes the wheel rakes popular so you have to factor that into my answer too.
   / Hay rakes #8
I've always been curious about a rotary rake. I got the chance to bale behind one and hated it. I'm used to a v-rake which makes the windrow the same width my baler is so I don't have to drunk bale, I just follow the windrow. The rotary rake did a good job as far as cleaning the ground but made a narrow windrow that required side to side baling.
My opinion the only rake to have is a v-rake.
   / Hay rakes #9
I've only been around a to rolabar rake and a wheeled v-rake. The v-rake can be set for baler pickup width and takes the stress off the baler driver. Makes a nice fluffy windrow. The rolabar (NH & IH) did good jobs but seamed to leave a lot unless you really run the teeth in the dirt. Even with no missing teeth. Both rakes seamed to rope the hay. NH not as bad but they do. 256 & 258. Plus with the rolabar to rake doubles for a round baler you have to out run the baler. With the v-rake it's pass for pass.
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
(INOP) SNORKELIFT TB60 TELESCOPIC MANLIFT (A51243)
(INOP) SNORKELIFT...
JCT SKID STEER QUICK ATTACH AUGER SET (A51243)
JCT SKID STEER...
International 56 2-Row Pull Cornplanter (A50774)
International 56...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
