Hay Rake
   / Hay Rake #1
steveky
Philpot, Ky
Kubota/ L3010HST, BX 1800
Anyone have any experience with a 3 point hitch wheel rake? I've only used the bar type rakes in the past, but thinking about purchasing a wheel type. What is the correct technique for using them. A neighbor said he just drops his and drags it, nothing to it...the local implement dealer said to set the teeth to where they are barely touching the ground, who's correct?
Steve
   / Hay Rake #2
You can just drop and rake, but it will break the tines. I try to put enough weight on the tines so that they stay on the ground but not carrying all the weight of the rake.
   / Hay Rake
Thanks, I assume you would want to also increase the angle with heavier hay? How well do these rakes perform with real heavy hay?
Steve
   / Hay Rake #5
If in heavier hay, you will need to keep an eye on it. Because, it will ball up the hay, once in a while . The next rake that I get will be a bar rake.
2016 John Deere 326E (A47477)
2016 John Deere...
FUEL TANK/TOOLBOX COMBO (A53843)
FUEL TANK/TOOLBOX...
2014 MACK GU713 WATER TRUCK (A51247)
2014 MACK GU713...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
SET OF (4) 11R24.5 TIRES (A53843)
SET OF (4) 11R24.5...
40' SHIPPING CONTAINER (A53843)
40' SHIPPING...
