Hay moisture testers
/ Hay moisture testers #1
Sawdustsmb
Greene, NY
TL80a, Ford 4000, Super H, F 12, F14
9am and it 6 degrees out - seems like a strange time to be posting this!!! I've made small squares for 50 years and am about to start a new adventure. Round baleage wrapped. How many of you use moisture sensors, are they worth their expense, and what types are best. Sorry if there is a thread on this already, I did a search but didn't seem to come up with anything. Thank you, Bob
/ Hay moisture testers #2
I run the new style Delmhorst cintinuous update (with shoes in the bailers) and the Delmhorst can come out of the tractor and be used as a handheld unit, the others can't (like agtronics).
I assume you are using that in a square baler - can it also be set up in a round baler?
/ Hay moisture testers #4
Moisture testers can be mounted on round balers. If you are doing baleage, choose your tester carefully to be sure it will test in the range you will be baling. Know that the same sensors in a round baler probably will not be as accurate as in a square baler due to a square baler typically testing cut stems. Round balers present only the stem sides to the sensor pads.
Thanks, Rick
/ Hay moisture testers #6
I have John deeres baler mounted moisture tester in my round baler, the install was easy but the calibrating takes a little getting used to, I used a hand held moisture tester and set the moisture level that it read in the baler mounted and every time I got different readings. I had to find a happy medium and average from there.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
KMC 3PT W/ 3 X 3 TOOL BAR (A64278)
KMC 3PT W/ 3 X 3...
2022 EZ-GO ELITE...
JOHN DEERE 8360R TRACTOR (A64278)
JOHN DEERE 8360R...
2007 Mercedes-Benz C230 Sedan (A64557)
2007 Mercedes-Benz...
2021 Caterpillar 279D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
