hay making
   / hay making #11
I've seen square balers that will run on 30hp (PTO)tractors. If you cut, rake, and bale as a 3 pass operation, sounds like you could make it.
Soundguy
   / hay making #12
Problem on those 30 hp tractors is most of them that I've ever seen run a baler are the old full size tractors. That you may be able to get away with. I've never seen a compact that small run a baler though.
Rich,
Congratulations on your tractor purchase. Too bad you aren't here. There is a really nice haybine moco by JD that is for sale for $3000 right by where I live. I doubt it will be there long at that price.
   / hay making #13
Here is an interesting article about hay making:
http://www.18james.com/rural/hay.shtml
www.agriquip.com has smaller hay making equipment. I have no idea of costs.
Article above references the JD 14T baler for under 30 HP tractors. Looks like you may be able to find these at auctions or listed in some classifieds for $1000 and under. Don't know anything about them, just listing it as an option.
   / hay making #14
Barticus, I got the Oliver at an auction for $5000. It has a loader, and is in excellent shape, except for the steering. The auctioneer, who is a dealer, agreed to give me any parts to fix the steering for free, so I'm just paying for labor which will be just a few hundred bucks. So I got a tractor for haying with a loader for less than $5500. It's a 1967 Oliver 1550, and it's 2wd and gas. I actually wanted gas. Most of you guys will think I'm nuts, but I feel that gas is much quieter and much easier to start in the winter. If you're willing to go with a vintage tractor, you can get a lot of bang for the buck, and if it has been well maintained over the years, it will serve you well. I also have a 1951 Ferguson that I love, and it's been a real workhorse for me. I've done a lot of research on vintage tractors for haying, so if you decide to go that route, I'd be happy to help any way I can.
   / hay making #15
Thanks, Richard! I hope to get a moco soon, but I may have to try to make due with the first harvest with a sicklebar. Eventually, I'll have the moco, and do it right.
   / hay making #16
Only thing I can say is the older tractors like my 1950 Case DC must have been rated on the conserative side. Has a 250 cubic inch 4 cyl engine with red line at 1250 RPM. I regularly run a Case square baler and never really lugged the engine and it's rated 33 (or so) HP.
   / hay making #17
I'll second skent on the conservative ratings on the older tractors. I have an old 1952 Case DC that seems to have quite a bit more power than the official rating would indicate. When I was a kid I regularly helped the neighbors cut and bale hay for their horses. They used an old John Deere A, which is rated somewhere around 30-35 PTO horsepower, to run their New Holland square baler. We would hitch a hay wagon behind the baler so we could grab the bales and stack them on the wagon as they came out of the baler. That old JD would run the baler and tow a heaping wagonload of hay without any trouble. I can still hear the sound of that old Johnny Popper working./w3tcompact/icons/smile.gif To cut and rake the hay they used an old Oliver 60 or a Farmall C with a trailer type Cockshutt sickle bar mower and a ground driven side-delivery rake.
   / hay making #18
I agree! My Ferguson TO-20 is rated 25 horsepower, but it sure seems more powerful than that. I have no trouble brush hogging on steep hills or pulling a pto driven manure spreader on steep hills with my Fergie. I always felt that, somehow, the ratings on vintage tractors were different.
   / hay making #19
I agree on the vintage tractors. Our neighbor runs a 2 cyl gas jd ( model 40 I think ) and bales with it.
Alot may have to do with weight. Some of the smaller compacts have similar HP as older models, but only half the weight. I also think the way generated hp is used and the way the engine and trans are / were designed has changed the picture a bit. The lugging capability of certain engines, large flywheels, etc.
Most notably, kubotas have a lower weight ( in general ) at the same hp rating as some of the other common compacts. Aslso, I was at the massey fergusion dealership yester day looking at a 1220, and a 1225. These units are sopposedly 20 and 25 hp respectively.. but were not much bigger than a large riding mower, and as a comparison, were probably 20 to 30% smaller than a NH tc18......
If the HP values are correct.. one can only assume that the lighter MF tractors would be slightly challanged when it came to heavier implimints, as opposed to say a less hp tc18 which was larger.... go figure.
Soundguy
   / hay making #20
Soundguy, I agree with you on the weight. Also some of the engines are so different on vintage tractors. My Oliver has a 6 cylinder gas engine. You'll never find a 6 cylinder engine in a tractor today. Even my Ferguson has a 4 cylinder gas engine. Maybe the bigger engines somehow relate to more horsepower than they were rated for.
TANK MANIFOLD (A55745)
21012 (A55853)
21012 (A55853)
UNUSED SDLANCH SDLE20 EXCAVATOR (A57192)
UNUSED SDLANCH...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A56858)
2012 Mack CXU613...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
2018 Ford Explorer AWD SUV (A53424)
2018 Ford Explorer...
